It is currently Thu Jun 20, 2024 5:47 am
![Post Post](./styles/acidtech/imageset/icon_topic_latest.gif) Re: What have you done to your Bronco today? (v.2)
Tue Mar 05, 2019 8:22 pm |
Wed Mar 06, 2019 9:24 pm |
Strike2
Drove it to work today with great success. quote]
I noticed that you were showing off the new exhaust system by parking up on a snow drift !!
Thu Mar 07, 2019 10:01 am |
Fri Mar 08, 2019 8:10 am |
Can someone else take the bad bronco karma?
Mon Mar 11, 2019 7:13 am |
You're not parked next to a jeep or something are you?
Mon Mar 11, 2019 7:41 am |
How does that happen?
Mon Mar 11, 2019 2:51 pm |
Tue Mar 12, 2019 12:56 pm |
Trans is fixed. Shift kit installed and works great. Man I really like the way this thing runs finally. Now to fix/upgrade/clean up some wiring and I'll be ready for summer.
Sat Mar 16, 2019 6:24 pm |
Gnsteam
First day out of the garage, what a long winter. Sorry no picture.
Sun Mar 17, 2019 4:42 pm |
crawlercreations
Figured it was time for STICKIES! They're about .5" shorter than my 40" MTRs. No big deal, the sticky part should take care of that!
Mon Mar 18, 2019 2:31 pm |
Game changer!!
Mon Mar 18, 2019 3:27 pm |
crawlercreations
Mon Mar 18, 2019 4:45 pm |
Yeah, I am just a parrot repeating what I have heard from folks I know. I have no personal experience.
Mon Mar 18, 2019 4:50 pm |
Mon Mar 18, 2019 7:11 pm |
Well, since my brake booster/bracket wasn’t playing nice, me and the Boy decided to take out MY frustrations on new Radius Arm Bushings!
We Win!!! (Sorta ;)
Sat Mar 23, 2019 7:44 pm |
BOBS 2 68S
Well not to the Bronco but for the Bronco New jack stands. Square tubing 3 inch and 2 1/2, 18 to 31 inches high. Cost $15.00 for angle iron every thing I had laying around. I have enough to build another set. Will sand blast and paint this summer
Sat Mar 23, 2019 8:05 pm |
Nice set of stands!
Mon Mar 25, 2019 7:45 am |
Nothing compared to digger but here's what I spent the last few days doing. Built a mount for my compressor and tank.
Mon Apr 01, 2019 7:57 pm |
That will be nice to have a tank! Wish I had done something to incorporate that into my setup. Someday!
Tue Apr 02, 2019 9:17 am |
Tue Apr 02, 2019 10:16 am |
Wed Apr 03, 2019 11:15 am |
That's exactly my plan at some point. Would love to look at your setup
Sat Apr 06, 2019 11:34 am |
Inching closer. At some point I’ll be out of meaningless projects and I’ll HAVE to fire it up!!!
...but not today
Sun Apr 07, 2019 6:48 pm |
Strike2
Sun Apr 07, 2019 8:25 pm |
I was only looking for some decent “Colorful Colorado” replacements. Mudflaps on a Bronco!??? Yeah... I’m that guy
I guess these will have to do?
Tue Apr 16, 2019 10:47 pm |
Yeah, it is too bad you couldn't find a new set of the old ones, but these are cool too!
Wed Apr 17, 2019 6:53 am |
Got a crucial piece of the puzzle in today! ***Thank you Justin for the BIG tank and thank you BroncoRaider for the Fuel Pump! Is there anywhere under the hood for a good power source In “ON” I don’t want to have to pull the ignition switch out from under the dash so looking for an easier way to hook up that pump.
Sun May 26, 2019 5:14 pm |
BOBS 2 68S
For me it's not what have I done but what I haven't done. Pulled the timing chain and gears out, installed new set. While it was down I swapped the differentials out of one Bronco to the other from 3:50 to 4:11. It made a big difference. Then the motor dropped oil pressure new Valvoline 10-40 with FL1A oil filter. Cold 80 lb pressure warm 40 pounds. 100 miles later the warm pressure drop's to 25 . I pull oil pan and looked at 2 main and rod bearings, the bearings have the look like they ran without oil. Crankshaft end play is .006. Bottom line I have no faith in this motor that it will no brake on the road. I spent most of last summer fighting this motor. So my wife asked me to just buy a crate motor. I installed a Blue Print long block 302 roller. From Summit Racing. Motor is bolted in and hope to have it running by this weekend
Tue May 28, 2019 5:37 am |
Tue May 28, 2019 10:44 am |
