you start hearing a funny noise in the engine.... Drive 11 miles watching the temp closel... Never gets hot at all, drain the oil, drop the pan and find metal, lots of metal.... Oil pump failed.
hockeydad4-22 wrote:You know what sux?
you start hearing a funny noise in the engine.... Drive 11 miles watching the temp closel... Never gets hot at all, drain the oil, drop the pan and find metal, lots of metal.... Oil pump failed.![]()
777mechanic wrote:buy the bosch glow plugs they burn much hotter , it takes about 45 minutes to do each side .
Jesus_man wrote:hockeydad4-22 wrote:You know what sux?
Dang!! If it weren't for bad luck, we wouldn't have any luck at all!
Viperwolf1 wrote:A carb engine swap is only a couple hours of work for 3 or 4 guys. Find the engine and we can make it happen.
kinder wrote:Getting jerked around by "The Man." Story overs when I get home...
crawlercreations wrote:Not many things suck in my opinion, but I finally found one. When you work really hard to build something unlike anything else out there only to see a fabrication shop copy the design almost to a T! Then when you call them on it they deny every bit of it and claim it is nothing alike. That is pathetic. If he had said: wow, that is extremely similar... I guess great minds think alike. Or something like that I would have been fine with it, but to flat out deny it. Very sad.
Rant off.:)
Rant off.:)
Jesus_man wrote:You're ball mount? Seems trailers are easy targets., Lock your ramps up and anything that can be moved. My cousin even had his whole trailer stolen. He saw the perps using it a week later and followed them. Called the cops and got it back, but you can't be too careful. I need to figure out a way to lock my ramps down.
zillacon wrote:You know what Sux? When your Diesel takes over a $100 to fill the tank and the pump shuts off at $75 and you have to swipe it agian to fill it all the way up.
Users browsing this forum: Google [Bot] and 4 guests
