Postby 66and70Broncos » Mon Jun 13, 2011 8:42 pm
It was good to meet and talk Broncos for awhile...I really appreciate the frame. I wasn't sure i'd be able to use it, but it worked out great. I'm glad I could just straighten the one rather than trying to weld 2 together and get it right. I owe you one!
Old EB 1966 I-6 170
New EB 1970 V-8 302
Next EB ? 5.0 EFI
Life is 10% what happens to you, and 90% how you react to it.
66and70Broncos
Postby WestMuddy » Tue Jun 14, 2011 12:23 pm
GMAN wrote:Saturday, I finished my hydroboost WOW what a difference ... Now I can SEE and STOP
I am intrested in your hydroboost. I am halfway through a disc conversion and am still trying to figure out how I am going to add a boost. I plan to hook up the proportioning/residual pressure valve from an '84 Jeep Wagoneer to the original master cylinder. At the moment I have no idea how well that will work.
WestMuddy
Postby sbolt19 » Tue Jun 14, 2011 12:57 pm
WestMuddy wrote:I am intrested in your hydroboost. I am halfway through a disc conversion and am still trying to figure out how I am going to add a boost. I plan to hook up the proportioning/residual pressure valve from an '84 Jeep Wagoneer to the original master cylinder. At the moment I have no idea how well that will work.
This is a what if scenario, but you might not have to use a prop valve. I used the original EB splitter block and have been for 4-5 years without a problem. Sometimes you need it, some times you don't, it just depends on if your Bronco lets you. I have seen where the exact same setup as mine required a prop valve and then you have me, who didn't need it. Just to clip a coupon, try doing it with out and see how it works, if it doesn't, then get your valve. Unless it is a daily driver, what does it hurt?
sbolt19
Postby ZOSO » Tue Jun 14, 2011 3:28 pm
Filled the bottle for the welder. Hoping to finish atleast the passenger floor pan this saturday after the breakfast since imnot workin.
Postby Shawns Fords » Tue Jun 14, 2011 4:10 pm
Classic69Bronco wrote:Took the Bronco out on Saturday, put about 30miles on it. Suspension is crazy loose. Got my first taste of death wobble, I am pretty sure that the car behind thought I was drunk.
Yesterday, I started on my 3spd floor shifter and t-case lever conversion. I have to adjust my 2 to 3 linkage, grinding a bit going in 2nd. I still need to attach the t-case linkage.
It was a good weekend.
what type of shifter is that? I have a Mr gasket shifter I picked up to install if I can not get my column shift to work and do not want to cut a big hole in my floor if I do not have to but I may end up doing that anyway. I dont know if this shifter I have will even work after looking under there at least ten different times. I think ill go look again right now.
I swapped my rear tires n rims out for a different set. need to find one more matching white spoke (or black) 16" rim to have a complete set.
Shawns Fords
Postby Shawns Fords » Tue Jun 14, 2011 4:14 pm
66and70Broncos wrote:Thanks to Classic69Bronco who gave me a donor Wshield frame...Today was spent removing the old WS...straightening the new one and reworking some of the problem areas on the new WS. At the end of the day...I have a straight frame that's rewelded in the corners, smoothed, and painted on one side...
I have to say up front that the WS frame I had had the worst rot Ive ever seen at the bottom...and whoever decided that 38 spot welds was what it would take to keep the WS frame on needs smacked in the head...
and YES...I USED A FORKLIFT TO PULL MY WS FRAME STRAIGHT...whatever works!
I need to weld mine back down onto the hinge, did you have problems with getting it set correctly when you mounted it on the hinge?
Shawns Fords
Postby 66and70Broncos » Tue Jun 14, 2011 4:44 pm
I'll have to get back to you on that one...I just have the two bolts in it for now. I wanted to get both sides painted and the areas that are hidden by the windshield painted before welding it.
My plan though is to put both bolts in...then put some light tack welds at the ends. Hopefully its enough to keep it in the right place when I fold the windshield down to weld. And by the way...Im not planning to put nearly as many welds down as it comes with...38-44 spot welds is overkill in my opinion...especially when its staying in place just fine with just the two bolts on.
If you get to yours before I do, let me know how it goes. Thanks
Old EB 1966 I-6 170
New EB 1970 V-8 302
Next EB ? 5.0 EFI
66and70Broncos
Postby airbur » Wed Jun 15, 2011 5:03 am
Drove up to Roadrunner Fabrication and picked up my powdercoated cage:) Had 3 buddies over last night and we had the thing mounted and bolted down (28 of them) in about 1 hour. I couldn't be happier with it. We went for a drive and there wasn't one rattle or noise from it. Will post pics soon in the other thread.
airbur
Postby Moab Mike » Wed Jun 15, 2011 6:19 am
Disassembled the front axle sans the carrier, ordered and received a master rebuild kit for the same. All ready now for the tech class next weekend.
Pulled the tranny pan and replaced the filter as well as pulled the reverse servo cover and replaced the seal.
Moab Mike
Postby hockeydad4-22 » Wed Jun 15, 2011 6:39 am
Drew welded in the hitch in the rear bumper and all the end caps, it is done... (finally). Then we adjusted the track bar to bring the front axle over about 3/8" (new tires causing serious rub on drivers side radius arms... now need to re-center the steering wheel and alignment) but tire rub is the same both sides and very minimal. Spacers or more offset wheels will fix it.
Good thing we have the adjustable track bar - there is no more in it, shortest possible, and it is about 3/4" shorter than the stock one.
Postby ZOSO » Wed Jun 15, 2011 12:42 pm
zillacon wrote:Ordered a rebuild kit for my Tranny along with new motor and Tranfer mounts. Toms macthed Advanced prices with no questions asked.
What tranny are you going with?
Postby Entourage » Wed Jun 15, 2011 9:42 pm
Dan is going with the one that had a Camper for sale a while back. laughing2
Postby ZOSO » Thu Jun 16, 2011 4:57 am
As long as he gets the camper too.
Postby cobshane » Thu Jun 16, 2011 6:20 am
The Dana 44 is in with new Dom steering and wh springs. Those rancho lift springs are history and WOW what a huge difference.
cobshane
Images: 1
Postby WestMuddy » Thu Jun 16, 2011 10:39 am
Today plus a few before today:
• ’74 or ’75 Bronco Dana 44 w/3.54 gears (in progress)
• 2 – Jeep steering knuckles
• 2 - Chevy spindles and seals
• 1 – Chevy backing plate, 1 – Jeep backing plate
• 2 – Jeep calipers
• 2 – Ford hubs and rotors
• All new wheel bearings and seals
Coming soon:
• 1 – Jeep Proportioning / Residual Pressure Valve
• 3.50 front gears (if the R&P I picked up at a junk yard fit)
• NP435
WestMuddy
Postby cobshane » Thu Jun 16, 2011 10:37 pm
Today finally made a t case shifter. A pry bar.just doesn't cut it.
cobshane
Images: 1
Postby airbur » Tue Jun 21, 2011 7:46 pm
Removed and replaced the fuel pump and filter. Got it running with no leaks and took the family to DazBog and the park. fire fire
airbur
Postby cobshane » Tue Jun 21, 2011 8:54 pm
I may not have 8 balls, but do have 8 lugs on all fours finally. Thanks to aka frank castle for gettng the 3/4 ton spindles and backing plates.
cobshane
Images: 1
Postby cobshane » Wed Jun 22, 2011 8:40 pm
L
zillacon wrote:Removed the Explorer harness off my motor, cleaned things up read up on EFI conversions until my eyes bugged out and touched the computer screen.
Also ordered my RJM harness today, LUK clutch, pilot bushing, throw out bearing, clutch equalizer bracket, EFI Tank, pump, sending unit, o2 Bungs, throttle cable and fuel lines. I am still cooling off my Debit card under a bag of ice and really should drink a beer. The wife is gonna bangtard
I would say at least once a week I get bangtard on the head.
so what's the trans gong to be, so much suspense! ! If your doing six speed its the new venture isn't it.
cobshane
Images: 1
Postby cobshane » Wed Jun 22, 2011 8:50 pm
Going Efi is not cheap for sure.
cobshane
Images: 1
Postby 66and70Broncos » Wed Jun 22, 2011 9:52 pm
Just drove it to and from work...but I have big plans for next week.
How many of you use your Bronco as a daily driver?
Old EB 1966 I-6 170
New EB 1970 V-8 302
Next EB ? 5.0 EFI
66and70Broncos
Postby Entourage » Wed Jun 22, 2011 11:42 pm
I installed my 1" Body Lift tonight. I am shocked how big a difference it makes - air cleaner fits, moves 23 gallon tank up, more clearance on rear tires, wiring will hide above frame, and just all around looks better. Love the WH kit with the integrated 1" bushings.
66and70Broncos wrote:Just drove it to and from work...but I have big plans for next week.
I am going to start driving my Bronco on Fridays when the weather is nice. What are your plans for next week?
Postby 66and70Broncos » Thu Jun 23, 2011 3:27 pm
Well...if all goes as planned...I intend to get some bodywork done. Primarily replace the rockers which I've had for over a month now. There's just not enough hours in a day!
Old EB 1966 I-6 170
New EB 1970 V-8 302
Next EB ? 5.0 EFI
66and70Broncos
Postby Justin » Thu Jun 23, 2011 8:01 pm
Got some safety upgrades done. Installed my shiny new 3 point belts to get rid of the dangerously mounted 4 point harnesses. Went through and replaced most of the mounting hardware on my roll bar. Turns out the previous owner didn't believe in putting washers between the body and the nuts, added some great big ones to reinforce the body a little.
Postby cobshane » Thu Jun 23, 2011 10:02 pm
Justin wrote:Got some safety upgrades done. Installed my shiny new 3 point belts to get rid of the dangerously mounted 4 point harnesses. Went through and replaced most of the mounting hardware on my roll bar. Turns out the previous owner didn't believe in putting washers between the body and the nuts, added some great big ones to reinforce the body a little.
Why were they mounted so dangerously. Were they welded into sheet metal. I have seen it before bangtard
cobshane
Images: 1
Postby cobshane » Thu Jun 23, 2011 10:14 pm
Built a new track bar and mount. Wish I would have made a little taller, but functions good. No bump steer and took off my lowering bracket, since i have heard the horror stories of frames shearing apart
Also I did a little tweaking on a rail barrier at work.
cobshane
Images: 1
Postby Justin » Thu Jun 23, 2011 10:50 pm
The shoulder straps were mounted to the roll bar. I'm sure they would have done a fine job of breaking my collarbones as I slid through them in a wreck. One side of the lap belts was bolted through the sheet metal with only a 1" washer for reinforcement. The other side was mounted in the factory location, so that was OK. Some of the stuff on my truck was done really well, others not so much.
Postby Shawns Fords » Sat Jun 25, 2011 6:06 pm
I looked at it. :)
Shawns Fords
Postby Lobobronco » Sat Jun 25, 2011 6:39 pm
Hung out with a bunch of yahoos from here and decided to buy a locker!
Fun day indeed!
Matt
Lobobronco
Postby Shawns Fords » Sun Jun 26, 2011 5:11 pm
Picked up a Hurst shifter from Jason on here and cut my hole in the floor, mounted the brackets and fought with the linkage. Found some pics of the assemblies with linkage but it doesnt seem to want to fit right on mine.
Shawns Fords
Return to Chit Chat
