www.ColoradoClassicBroncos.com - View topic - What have you done to your Bronco today? (v.2)
It is currently Sat Nov 23, 2024 4:26 pm
Reply to topic  [ 2657 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 89  Next
Post Re: What have you done to your Bronco today? (v.2)
Mon Jul 04, 2011 4:14 pm
Mon Jul 04, 2011 6:11 pm
took a chance at Pueblo Nationals and bought a mirror that looked like a Bronco mirror. Perfect fit...what are the chances of that...perfect chrome and mirror and paid 5 bucks! I guess ya win a few :)
So...today...mirror installed. Finished painting WS frame and back on the truck. Started tapping out a dent in the front fender with the new in box hammer/dolly set I picked up for 15 bucks off of CL. It sure was nice to have some time to work on the Bronco.
Tonight...planning to drive up to Garden of the Gods in the Bronco to watch fireworks...if Manitou is having them anyway.
Old EB 1966 I-6 170
New EB 1970 V-8 302
Next EB ? 5.0 EFI
Life is 10% what happens to you, and 90% how you react to it.
Mon Jul 04, 2011 7:00 pm
Installed new WH Chromoly HD 31 Spline Rear Axles ending a 2 month battle with the old axles with 3 bolt patterns, wheel spacers, tires sticking out too far, front wheel spacers to match the rears, caster, torquing spacers, leaning tires, etc. Really excited how they turned out.
Sent Jim at WH an Email with 3 pics of my rear brake setup and sent ALL the exact parts I needed - correct axles, bushings, seals, bearings, and retainers. I am so dang happy we have WH as a resource and never need to worry about rear axles again.
A BIG thanks to Zilla for pressing the new axle parts today (yes on a Holiday) - luckily I didn't break anything at his shop today. lmao
Mon Jul 04, 2011 9:44 pm
Picked up my new lower half of the steering shaft from the machine shop (had to have a spot cut for the spring). Perfect fit! I now have an acceptable steering shaft, just need to pick up the U-joint for it.
Thu Jul 07, 2011 12:06 pm
Got the WH flares installed. Had to remove most of the inner fenders but it worked out ok. Now to the fork lift to see what else hits...
Sat Jul 09, 2011 2:30 pm
Got a bunch of parts from Bronco Hut. My son threw up in their driveway.
Sat Jul 09, 2011 4:09 pm
Removed part of my work bench so that my Bronco can back in with the added tire carrier and front bumper so I can fit all 3 cars in my garage.
Sat Jul 09, 2011 4:18 pm
I had to do the same thing. May have to re-do it if we get my bumper finished next weekend. Major PITA.
Sat Jul 09, 2011 5:15 pm
Helped drop both tanks. Got em both cleaned out and hoses replaced. Next is twin stick setup.
Sat Jul 09, 2011 5:43 pm
Got the rear end back in Ol' Blue and the rear brakes put back together too. It seams like the e-brake cables that were supposed to be 5" longer are 5" shorter. I also found out that the drive shaft will need to be lengthened. It should be back on the road by next weekend.
Sat Jul 09, 2011 5:45 pm
Sat Jul 09, 2011 5:57 pm
Thanks to 76 Ford Bronco, the old Lone Wolf is back on the road. Plugs, wires, cap, etc, etc. Thanks for all your help 76 Ford Bronco.
Sat Jul 09, 2011 6:29 pm
Nice Job 76 smokin
Sat Jul 09, 2011 6:43 pm
Took my kiddos to O'Fallon Park which is just south of Evergreen along the river.
Great summer day of swimming, floating down "the rapids", and water toys.
I had it all shined up so lots of folks came over to ask what year it was and give a compliment.
Sat Jul 09, 2011 6:47 pm
You guys have been busy this weekend!!
I trimmed up from brackets that were interfering with my rear shackles, did some moving of rear inner fenders to keep the tires from rubbing, figured out how to remove my hard top by myself and put the bikini top on!!
Sat Jul 09, 2011 8:03 pm
Sat Jul 09, 2011 8:23 pm
Pulled my steering column and shaft out of the truck, prepped everything for installation of my '72 F-250 column and collapsible lower shaft. The OG manual box has the same spline size as the 4x4x2 box going in, so it'll be a direct bolt up to my PS setup.
Sat Jul 09, 2011 10:47 pm
Got the Bronco running again. As always its the last thing you think of. banghead
Sun Jul 10, 2011 3:01 pm
A very special Thank You to Rox Crusher for helping me put the finishing touches on the lift kit install. We were able to take a spin down the street under its own power. Still have several things to do to call it complete but I'm sitting in a much better position with Rox's help today.
Sun Jul 10, 2011 7:13 pm
Sun Jul 10, 2011 7:37 pm
Sun Jul 10, 2011 8:20 pm
Sun Jul 10, 2011 8:46 pm
Sun Jul 10, 2011 8:51 pm
The plan now is to lengthen the rear drive shaft and then buy some tires big enough to wheel but small enough to keep from ripping the quarter panels up. Some of the sizes I'm seeing aren't allowing me to go too crazy. I'm also looking at moving the axle back too. I should be wheeling with no problem in Ouray and after that, wherever you want to go![/quote]
brain fart How about some big flairs, Cut the crap out of it and some 35's if not 37's.
icon biggin laughing2[/quote]
Not until I hand the keys over to the future owner (who helped with the lift install) then it's up to him!
Sun Jul 10, 2011 9:00 pm
Wed Jul 13, 2011 6:41 am
I installed my roll bar with 4 Bolts during the build to make sure I liked the position with the BesTop, wipers, etc. Last night I drilled and added the other 20 Bolts.
Wed Jul 13, 2011 9:32 am
Ordered the parts from WH for the column shift collar repairs. Hope to have them by Friday for this weekends shop/tech day. Now to get the rear brakes ordered....
Wed Jul 13, 2011 10:35 am
Drove to the pool....3 min away.....and it died as I pulled into the parking lot. Futzed around with it for 10 min and finally got it started. Ordered a new coil and condenser.
Wed Jul 13, 2011 8:37 pm
OH OH OH i did something today. I drilled the holes for the seat in the new passenger side floor pans. Also cleaned it out so I can get ready to possibly sand blast the floor and coat it with por15 once I get the driver side floor replaced.
Wed Jul 13, 2011 8:42 pm
Users browsing this forum: No registered users and 11 guests
32,976,729 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
