www.ColoradoClassicBroncos.com - View topic - What have you done to your Bronco today? (v.2)
It is currently Sat Nov 23, 2024 6:59 pm
Reply to topic  [ 2657 posts ]  Go to page Previous  1 ... 16, 17, 18, 19, 20, 21, 22 ... 89  Next
Post Re: What have you done to your Bronco today? (v.2)
Sat Aug 20, 2011 4:03 am
Routed the fuel lines through the frame from the tank to under the hood to avoid the exhaust. Re wired the electric fuel pump, adjusted the idle so it doesn't stall at every stop light and stop sign, and.....
DROVE IT!
No vapor lock, no stall, no problems!
Yeeaaahhyaa!
Going to play with the timing here in a few and......
DRIVE IT SOME MORE!!!!
Sun Aug 21, 2011 11:25 am
Mon Aug 22, 2011 7:40 am
Got the front shoulder belts installed on saturday and the weatherstrip/door seals on the drivers side done. I took the family up on a long trail drive up Ophir creek rd on the back side of the Greenhorn and we drove up to blue lakes (more of a pond). Had no issues (other than this thing squeaking like a stuck pig). Family had a blast. Jayson
74, MONEY EATER
Mon Aug 22, 2011 11:44 am
Finally got time to finish the radiator install. Plan to take a break from truck stuff and start in on the rear axle rebuild tomorrow if I can make time.
Mon Aug 22, 2011 10:00 pm
Tue Aug 23, 2011 7:16 pm
I looked at it. Wishing it still wasnt 100 freakin degrees out still. Im ready to get to workin on it.
Tue Aug 23, 2011 8:16 pm
I've been hacking away at my Mercury Mestique passenger seat & a Bronco II passenger seat bracket. I got the seat bracket for $20, and it was already unbolted from the truck. I think, with some heavy modification I can make it work. I've test fit the bracket & seat shell 10x, carefully cutting to get the fit right. The overall size/shape of the new seat is very similar to the original Bronco seat. The Bronco II bracket is just about the height of the step in the floor. I expect the new seat bottom to sit down on the floor just the way the old seat does. Hope to be done by this weekend. I'll take everything apart & post up better pics in a thread when its all done.
Chad
Tue Aug 23, 2011 8:31 pm
Disassembled the rear axle to check the condition of everything and to get things all set for new bearings. I also confirmed what the PO had told me about the parts it was built with: '76 or '77 big bearing housing, Currie nodular iron 3rd member with Currie 31 spline axles and an ARB locker. I was happy to find that the splines on the axles also look good and I think I've got the original Ford 4.10 gears. I'm hoping they're in good enough shape to not need replacing.
Tue Aug 23, 2011 11:39 pm
Thu Aug 25, 2011 7:45 pm
How much fuel in the tank? I wonder if the pump was overheating.
Thu Aug 25, 2011 8:08 pm
This is the EFI truck? Do you run both a low and a high pressure pump? 7/16" line?
Thu Aug 25, 2011 8:11 pm
I know on that bucket of a gm truck that I have to drive it has issues with this when you run it down to 1/4 or less. That and crappy gas. Maybe water in the tank?
Thu Aug 25, 2011 8:12 pm
The fuel picks up a lot of heat from the fuel rail. As hot as it's been out I can hear fuel percolating in my tank after I shutdown.
What kind of venting do you have on the tank? If it isn't vented it won't pump easily.
Thu Aug 25, 2011 8:45 pm
I am no expert, but in my research the in-tank pumps have been problematic for many. The suggested setup is to run a low pressure pump close to the tank on the frame rail to get the gas out of the tank, then a high pressure unit a short ways up the frame to do the heavy lifting.
Maybe the vent will help.
Thu Aug 25, 2011 8:54 pm
Thu Aug 25, 2011 9:00 pm
Well that narrows it down to a problem with the pump or the pickup. No reason an in-tank pump shouldn't work well. It might be sucking air from the pickup side. I assume the wiring is appropriately sized to deliver 10 amps or so.
Thu Aug 25, 2011 9:16 pm
Thu Aug 25, 2011 9:19 pm
Thu Aug 25, 2011 9:56 pm
Fri Aug 26, 2011 6:08 am
Adjusted the kickdown cable last night. It was a little tight and would drop down on the freeway (not good) so got it adjusted for highway driving.
Drove it to work today and realized it won't fit in the parking garage with the BesTop up. I guess it can park outside for a few hours laughing2
Fri Aug 26, 2011 10:33 am
I am sure she will be alright... You may need to pick up some cloth diapers at babies R us to wipe the dust off though.
icon biggin
I am telling you - she looks SWEET in that pic. Very nice job.
Fri Aug 26, 2011 10:43 am
At least you noticed BEFORE you pulled in. BTDT...
Fri Aug 26, 2011 11:07 am
Fri Aug 26, 2011 11:17 am
Fri Aug 26, 2011 1:59 pm
Fri Aug 26, 2011 4:42 pm
New stereo from car toys.
Kenwood installed for 125.
Fri Aug 26, 2011 5:28 pm
Pickin up the goodies to polish the turd... intake, serp, floors/rockers/door posts etc!! won't be long now
Sat Aug 27, 2011 2:51 am
Pretended to be a moving van and went to a new home. The Bronco towed his buddy to the storage yard.
Sat Aug 27, 2011 4:47 pm
That is a good lookin' utility trailer, can you give some details about it?
Sat Aug 27, 2011 5:00 pm
32,980,807 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
