www.ColoradoClassicBroncos.com - View topic - Birthday present needs a ride back to Colorado
It is currently Sun Nov 24, 2024 3:03 am
Reply to topic  [ 81 posts ]  Go to page Previous  1, 2, 3
Post Re: Birthday present needs a ride back to Colorado
SMS is where I bought the fabric. Bronco hut actually sells a bench seat upholstery kit but its just south of $600. The fabric cost me about $320 and having my guy make the covers and install is another 120-150 plus the foam which they will provide. When its all done, I'll be in this seat close to a grand. because of the powder coating on the seat frame. It sounds like a lot but I just don't care. How often do you see a 66 Bronco with an original bench seat in it? I can't wait to roll down the road on that damn seat. It also allows me to transfer my current seats which I reformed and covered a few years ago into the 68 Project for the boy. That will save us some time and $$ on that project. I'll keep the progress photos posted
Thu Sep 01, 2016 8:36 pm
Images: 11
Thanks. Looking forwrd to seeing it.
Thu Sep 01, 2016 8:38 pm
Thu Sep 01, 2016 9:36 pm
I talked to the powder Coater this morning and it's going to be under $100 for that plus the cost to blast the old paint and surface rust off. I'll finish getting it torn down tomorrow and repair any broken springs etc prior to taking it in
Fri Sep 02, 2016 9:10 pm
So the seat frame is stripped down. Now I have to repair a few of these broken springs before it goes off to blasting and powder coat
Mon Sep 05, 2016 5:58 pm
I used some steel tubing that I had to make a sleeve for the broken spring. I welded the ends in place turned up the heat and welded right through the tube from the back side.
It's not pretty but it's got to be stronger than tack weld it back together.
Mon Sep 05, 2016 6:11 pm
So, the outside spring was broken in two places.
Once again, it's not very pretty but it should support my narrow ass.
Mon Sep 05, 2016 6:37 pm
Luckily the guy that rode shotgun on the seat regularly was a little bit less taxing on the springs. Only one repair required on that side
Mon Sep 05, 2016 6:50 pm
The back of the seat had only one spring to repair. Unfortunately the spring wire was way too thin for me to consider welding it. So I took another piece of the steel tubing I had and crimped it onto the wire. And I use a pair of vise grips to crush the tubing down tighter. I don't think it's going anywhere.
Mon Sep 05, 2016 7:42 pm
Seat frame is back from blasting and powder coat. They look like new. Image
I'll just wet paint the sliders, We were going to coat them but the plastic knob
would have melted in the oven.
Last edited by casadejohnson on Fri Sep 09, 2016 12:59 am, edited 1 time in total.
Wed Sep 07, 2016 5:13 pm
Jeremy, you should add a couple seat heaters to make the winter morning drives a little nicer.
Wed Sep 07, 2016 10:30 pm
I was in a rush to get this thing done but I just found out my seat material will not be shipping for another week. Perhaps I will have some time to shop for seat heaters. I had not thought about that before. Maybe from Amazon?
Fri Sep 09, 2016 12:49 am
5 minutes on Amazon and I see that seat heaters can be had for $50-60 for a pair. That is much less than I expected, is that the going rate or is it because I'm looking at a crappy product? If thats the price I'm in. I could roll with no top deep into October with heated seats!
Fri Sep 09, 2016 1:03 am
That seems about right
Fri Sep 09, 2016 3:44 am
That's actually cheaper than some of the ones I've looked at. If they've got good reviews I'd pull the trigger.
Fri Sep 09, 2016 6:28 pm
The Dorman kits are more expensive, but well rated.
https://www.amazon.com/Dorman-628-040-U ... B002U6IL9O
In my opinion I'd rather spend a little more not to need to tear it apart and replace them.
Fri Sep 09, 2016 8:34 pm
I received my crazy expensive bronco seat fabric today.
Fri Sep 23, 2016 11:47 am
Installed, just need to hook up the seat heaters.
Mon Oct 10, 2016 7:34 am
Wow that looks great!
Mon Oct 10, 2016 9:47 am
Very nice. So cool you could end up with it. Thanks to Zac for making it happen!
Mon Oct 10, 2016 11:50 am
really looked great in person!
except for the broken glass everywhere
Mon Oct 10, 2016 5:16 pm
32,989,425 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
