Postby Jesus_man » Fri Oct 21, 2011 7:18 pm
Got it loaded on the trailer, ready for Chinamans!!
Postby Viperwolf1 » Fri Oct 21, 2011 7:43 pm
Took it for a spin up to Winsor to deliver Royce's C4.
Postby airbur » Mon Oct 24, 2011 4:31 am
zillacon wrote:Went wheeling up near Centennial Wyoming on Sat and finished running gas pipe to my garage heater so I can work in warmth.
I need to get on that. I'd love to have heat in there this winter.
airbur
Postby Rox Crusher » Mon Oct 24, 2011 4:51 am
not much really..........
cleaned up and painted the elusive 5.0 Ford steel oil pan and installed it
cleaned up the garage a bit to make it easier to work in
Postby WestMuddy » Mon Oct 24, 2011 3:39 pm
kinder wrote:That is a good lookin' utility trailer, can you give some details about it?
‘Sorry it has taken so long to respond; we’ve been kinda busy. The Bronco is basically parked w/o insurance because it is so sick.
It is a 1968 M101-A1 Army trailer. I bought it as scrap at a government auction without sides, canvas, tongue or wheels. It was rated as 3/4 ton which is an off-road rating. That means it is good for 1.5 tons on good roads. If you release the front pins on the tongue, block the wheels and back up, it will dump (see picture).
I fabricated a tongue with a hookup that will flip around; one way it accepts a 2” ball, the other way it accepts a 3” pintle. I cut off the original spindles that would only accept an obscure 5 bolt pattern that the army used on its M37 3/4 ton truck and welded on front spindles from a ’74 Bronco. That way it takes the same wheels as the bronco, although it probably reduced its load capacity to 1 ton. The next thing I need to do is put a jack on the front.
I traded some other Army junk for the sides and top and there it is. I’ve had up to 3,000 lb. in it and it tows great, although that is a bit heavy for a trailer without brakes. If someone is really interested, it might be for sale. I have my eye on some other Army equipment coming up for auction and I need the $$.
WestMuddy
Postby rdanford » Mon Oct 24, 2011 7:11 pm
Viper Built C4 was installed...WOW...new motor is awesome with the tranny working! Thanks again Phil!
Royce
2006 4Runner V8 Sport Edition
rdanford
Postby airbur » Mon Oct 24, 2011 7:20 pm
Drove it to Ace to pickup some bolts....on the way I turned the heater on to test for winter....damn that blower upgrade works wonders!
airbur
Postby Viperwolf1 » Mon Oct 24, 2011 7:46 pm
rdanford wrote:Viper Built C4 was installed...WOW...new motor is awesome with the tranny working! Thanks again Phil!
Sounds good. Let me know if you have any problems with it Royce.
BTW, if you're interested in seeing what internal mods I do to these just look in this thread. http://classicbroncos.com/forums/showth ... p?t=194032
Postby ZOSO » Tue Oct 25, 2011 7:12 pm
Havent done much. First time since 2001 that I didnt take it elk hunting. I must say it was pretty nice to drive the truck. But before I left I did look into why it wanders so bad down the road. Gonna build a track bar riser and ditch the drop bracket. It is flexing like crazy.
Postby D&D72 » Wed Oct 26, 2011 1:45 pm
I brushed off about 8" of snow off mine for the 1st time today.
D&D72
Postby D&D72 » Wed Oct 26, 2011 1:47 pm
ZOSO wrote:Havent done much. First time since 2001 that I didnt take it elk hunting. I must say it was pretty nice to drive the truck. But before I left I did look into why it wanders so bad down the road. Gonna build a track bar riser and ditch the drop bracket. It is flexing like crazy.
a successful hunt I hope??
D&D72
Postby ZOSO » Wed Oct 26, 2011 1:58 pm
I wish. We came home to beat the snow. We could have had a few if we had bull tags. But Pops and myself only had cow tags. On saturday we had 3 bulls walk out in front of us. Then sunday pops had a single bull walk out in front of him and I had people in front of me. There were a few cows and they shot them in front of me. Monday pops had a few more go by him but it was about 5 minutes too early and on private property. Then tuesday was not a single thing but a lot of cold wind.
Postby Gunnibronco » Wed Oct 26, 2011 4:21 pm
ZOSO wrote:
D&D72 wrote:successful hunt I hope??
First season, I spent 5 days in the woods, taking my gun on long walks, too. No luck. I saw 30-40 opening day at sunset, they were 2 very, very long miles away. Didn't see anymore after that.
Always next year.
Chad
Postby airbur » Thu Oct 27, 2011 6:47 pm
I didn't do anything to the Bronco today. I did install two 8 foot T8 florescent fixtures in the garage:) Total of 8 bulbs in there now...I can see!
http://www.homedepot.com/Lighting-Fans/ ... ogId=10053
airbur
Postby airbur » Fri Oct 28, 2011 7:18 am
I'm getting ready to do something similar. My entire garage is also on one 15 amp and when the compressor kicks on, it trips the breaker. I think I'm going to add a 20 amp breaker and run a line to a new outlet for the compressor and the heater.
airbur
Postby ZOSO » Fri Oct 28, 2011 7:40 am
Just set a 100 amp sub panel in the garage. That's what I did in boogers garage. Every outlet is its own 20 amp circuit. Plus tons of lights and the heater.
Postby Jesus_man » Fri Oct 28, 2011 7:50 am
Did a similar job on mine a couple years ago. Have (3) 8ft and (3) 4ft fluorescent and ran two new 4-gang 20 amp circuits between the doors on the garage. Been really nice. Everything in mine was also 15amp. weak!
Postby airbur » Fri Oct 28, 2011 8:05 am
I thought a about a sub panel...but since I still have a few open slots in the main one, I think I'll go the new circuit route instead. It's obvious that newer homes are not built with any hobbyists or mechanics in mind! 1 15Amp....bla!
airbur
Postby Gunnibronco » Fri Oct 28, 2011 11:17 am
I'm not done, but since everyone is bragging about the electric in their garage, I've set new 200 amp service to my entire home & ran a new 100a breaker panel in my garage. I haven't run the new circuits yet, just attached the old wiring to the new panel (don't tell the electric inspector). I do have an open electric permit to do my whole home, so the garage is going to have to be finished correctly. But I'll have plenty of room to grow after the inspectors leave. It will be nice. My whole home & garage were run off a 100 amp service, total. But since the home was built in 1882, and was still running some knob & tube when I started the upgrade, 100 amp was probably a lot when it was installed.
Chad
Postby D&D72 » Fri Oct 28, 2011 1:14 pm
airbur wrote:I thought a about a sub panel...but since I still have a few open slots in the main one, I think I'll go the new circuit route instead. It's obvious that newer homes are not built with any hobbyists or mechanics in mind! 1 15Amp....bla!
Not to mention how small garages are! a compact car fits great, nothing else does... expansion may be on the horizon.....
I also added a 20 amp circuit.
D&D72
Postby Jesus_man » Fri Oct 28, 2011 2:18 pm
D&D72 wrote:Not to mention how small garages are! a compact car fits great, nothing else does...
True-dat! You are hard pressed to find a garage that will house two vehicles comfortably! I lucked out somehow and got a garage with 14ft ceilings, which I have used for storage. But even being a 3-car garage, it's a very tight fit for three vehicles. My truck nearly has to touch the front wall to get the door to close. My previous garage, not a chance!
Postby ZOSO » Fri Oct 28, 2011 6:14 pm
Expansion for you? you must be the only house on that street that doesnt have a huge garage on the side or in the back. You think your garage is small try mine. The cobra has 6in in the front and to the rear with my one shelf. needs to be atleast ten foot deeper about 30foot wider and 10ft doors.
Postby D&D72 » Fri Oct 28, 2011 10:26 pm
The 2 car at my old place had more room. My kegerater barely fits! I'm thinking it would be nice another 10-12 ft wider and about 30 ft deep!
D&D72
Postby fsharp1@live.com » Sat Oct 29, 2011 6:44 pm
Started taking panels off today,
Front clip ,Doors, hood etc.
Hopefully tomorrow I can start draining all the fluids in preparations to yank the engine Trans and T-case.
"Friendship is like peeing on yourself: everyone can see it, but only you get the warm feeling that it brings."
!974 Bronco, 4x4, 302/ auto trans, All original for now
fsharp1@live.com
Postby Shawns Fords » Sat Oct 29, 2011 8:07 pm
Did a whole bunch of brake work on my F250 and when I was going through a tool box of parts I found an old Window crank handle from my 64 F100. I thought to myself "I sure could use my vise grips today" so I took the vise grips off of HULKs drivers door window crank and installed the handle. I really did do this today too. thumbs up
Oh I did think about Calling Greg to see if he had a hammer and a block of wood I could borrow to get my vice grips loose. jawdrop
Shawns Fords
Postby Justin » Sat Oct 29, 2011 8:22 pm
I followed my inner lemming and replaced a shop light that had burned out. I also finally got around to installing a 250w metal halide that I'm not using on my aquarium out in the shop. I'm hoping that in addition to providing blinding amounts of light that it will also keep me warm. brain fart
Used all that new light to take out my heater box and disassemble both it and my spare to take the best parts for a newly sealed, rebuilt heater. Picked up the parts yesterday for the upgraded motor and squirrel cage.
Postby Moab Mike » Sun Oct 30, 2011 7:46 pm
I bought a 1997 Ford Explorer motor complete with all the peripheral's. It has the GT40 (P) heads and upper/lower intake, yada, yada, yada. I get to pick it up next Saturday.
Moab Mike
Postby Gunnibronco » Sun Oct 30, 2011 7:49 pm
76fordbronco wrote:I bought a 1997 Ford Explorer motor complete with all the peripheral's. It has the GT40 (P) heads and upper/lower intake, yada, yada, yada. I get to pick it up next Saturday.
Sweet! I look forward to doing some trails with you next year! laughing2
Chad
Postby rdanford » Sun Oct 30, 2011 7:59 pm
Replaced front bump-stops and sealed up the interior a bit better for the winter
Royce
rdanford
Postby landshark » Mon Oct 31, 2011 6:07 am
i will tell you what.. i will take your "tight" 3 car garage any day over my 80+ year old single car garage!
Talk about creative storage and using the space wisely.. iam trying to figure out how to install shelves to store my spare parts and tools on while being able to open/get out of a vehicle. Most of my accessories for my fullsize bronco have to hang from the walls or ceilings as i have no storage above the rafters (flat roof). If only I didn't have a bathroom and kitchen remodel on the horizon i could do the garage.. oh well at least its easy to heat ;)
Return to Chit Chat
