Postby crawlercreations » Mon Mar 05, 2012 5:07 pm
Bought these today...boy am I glad I made my front clip to allow stock stuff to bolt on like stock!
I almost feel bad about cutting them up but I will!
Thanks boxerdad!!
crawlercreations
Postby Gunnibronco » Mon Mar 05, 2012 8:14 pm
I brought all my tools, a 351W, a used dash, and a new set of 3.5" W/H rear springs home from my old job at the body shop. Now I just need to get some work on my house done, so I get the barn wood, gas stove, and bath vanity installed in my home, and clear some space in the garage to pull my Bronco in.
Postby landshark » Tue Mar 06, 2012 12:25 am
Cursed at the rear drum brakes. What a pain in the ass!
Postby Viperwolf1 » Tue Mar 06, 2012 1:03 am
I finally got around to fixing my gear shifters so they match my window knobs.
Postby airbur » Wed Mar 07, 2012 5:55 am
Those are slick Viper!
I'm awaiting the UPS man's arrival today to drop off a Python alarm system I'll be installing. I also bought a 2 zone montion sensor as an add on. I'll probably hook up the starter kill and motion sensors.....since it's a soft top, I think that'll do.
airbur
Postby Entourage » Wed Mar 07, 2012 8:56 am
airbur wrote:Python alarm system I'll be installing. I also bought a 2 zone montion sensor as an add on. I'll probably hook up the starter kill and motion sensors.....since it's a soft top, I think that'll do.
I am planning one when my Bronco is finished as well. The Python is a great product. I LOVE doing my own stereo/amp/speaker installs, but I leave alarm installs to the pros.
Postby airbur » Wed Mar 07, 2012 9:00 am
Alarms are cake....if you can do stereo/amp/speaker installs, you can do this.
airbur
Postby airbur » Thu Mar 08, 2012 7:43 pm
Got the alarm installed today. Most time was spent running wires and figuring out which ones to tap. The starter kill is hooked up but it's not working yet. I know I have the right wire (blue/red) since when I pull the relay, it won't start. Not sure what the issue is yet.
While I was under there I decided to remount my fuel gauge selector switch. Since it doesn't fit in the stock spot with the cage, I mounted it just under the gauge cluster.
airbur
Postby Entourage » Thu Mar 08, 2012 9:52 pm
airbur wrote:Got the alarm installed today. Most time was spent running wires and figuring out which ones to tap. The starter kill is hooked up but it's not working yet. I know I have the right wire (blue/red) since when I pull the relay, it won't start. Not sure what the issue is yet.
While I was under there I decided to remount my fuel selector switch. Since it doesn't fit in the stock spot with the cage, I mounted it just under the gauge cluster.
Nice! I am very impressed. I may try my own. So did you get any extra sensors (glass breakage, force field, motion)?
Postby airbur » Fri Mar 09, 2012 5:32 am
Yes....I'll shoot you a PM...don't like being to descriptive of alarm setups publicly ;)
airbur
Postby crawlercreations » Sat Mar 10, 2012 6:27 pm
Finished and mostly installed my dash today! Still a little wiring to clean up and the stereo finish installed but this was a big step I wasn't looking forward to.
crawlercreations
Postby airbur » Sun Mar 11, 2012 5:59 am
crawlercreations wrote:Finished and mostly installed my dash today! Still a little wiring to clean up and the stereo finish installed but this was a big step I wasn't looking forward to.
Very nice! Great color.
airbur
Postby rdanford » Sun Mar 11, 2012 3:16 pm
casadejohnson and I pulled apart the 9"...getting 4.10s installed along with new seals and bearings on the axles.
Royce
2006 4Runner V8 Sport Edition
rdanford
Postby socofn » Sun Mar 11, 2012 8:15 pm
Got the aux fuel tank installed today (thanks to Troy for the tank). Now to get fuel in it and make sure it doesn't leak. JP
74, MONEY EATER
socofn
Postby airbur » Tue Mar 13, 2012 6:58 pm
New windshield and seal!...thanks to Hockeydad and son for the install!
airbur
Postby airbur » Wed Mar 14, 2012 5:18 pm
I got the windshield wipers and rear view mirror re-installed today. Also got the alarm receiver and LED mounted. New windshield looks great.
While the family and I were hanging outside this afternoon with the Bronco, a red Bronco pulled onto our street I'd never seen before. They swung around and stopped. We met Seth and his wife. They just bought the Bronco and got it tuned up so it's drivable. Very nice Bronco and a good starting point.
Was great to meet two new Bronco owners and friends. I mentioned the meet on Sat. but they can't make it.
airbur
Postby socofn » Wed Mar 14, 2012 9:09 pm
Not the bronco but I got the bronco hauler (trailer) bearings repacked and a missing cover replaced. Been driving the EB some and need to replace a couple of marker light covers. JP
74, MONEY EATER
socofn
Postby hockeydad4-22 » Sun Mar 18, 2012 4:53 am
In preparation for todays snow bash, we fitted the chains, loaded up the ammo cans worth fluids, tools and recovery equipment. We also finished the door panels, side panels and headliner, including covering the wiper cover with realtree camo fabric.
And we installed the 1.5 inch wheel spacers for a new wider stance and over all tougher look..... Oh yeah and the tires don't rub anymore
A snow bashin, here we go!
Postby rdanford » Sun Mar 18, 2012 1:53 pm
Looks great Dan...Can't wait to get them back in...Sending a PM now.
Royce
rdanford
Postby ZOSO » Sun Mar 18, 2012 5:21 pm
Hey I beat on mine a little bit. Got to run the winch cable some. Got to love wheelin.
Postby Booger » Sun Mar 18, 2012 6:27 pm
got to blow out a header gasket wheeling today.
Postby Jesus_man » Mon Mar 19, 2012 6:25 am
Got it dirty...
Postby Jesus_man » Mon Mar 19, 2012 6:56 am
Yeah, they still are. Need to dig the pressure washer out and give her a yearly bath.
Postby Jesus_man » Mon Mar 19, 2012 7:12 am
zillacon wrote:I tried to Hornswaggle Rob to come over and wash mine but he wasnt falling for that. LOL
Did you offer beer?
Postby Rox Crusher » Mon Mar 19, 2012 2:19 pm
wholly crap batman................placed big order with WH
- all new floor pans
- steering column rebuild components
- tuffy concealed weapon lockbox
- EB classic tachometer set up
Postby Entourage » Mon Mar 19, 2012 3:04 pm
Rox - you will love the concealed weapon lockbox - great way to utilize the un-used underseat space.
I removed the Wild Horses decal and installed my new CCB Window Sticker . . .
Postby hockeydad4-22 » Tue Mar 20, 2012 5:26 am
Rox Crusher wrote:wholly crap batman................placed big order with WH
All new floor pans?
Hmmm, starting to sound more and more like a full on frame off rebuild. Not just a refresh. Kind of like my wife telling me she will be ready to go in 45 minutes... yep - 45 minutes after we were supposed to leave.
Postby socofn » Tue Mar 20, 2012 7:26 am
Got a short somewhere as I was driving home and 100yards from the driveway the headlights flickered and went out to come back on. OH boy I love this thing. JP
74, MONEY EATER
socofn
Postby Justin » Tue Mar 20, 2012 8:17 am
Take a look at your high beam switch. Mine did exactly the same thing and that was the issue. You can run a jumper around it to connect the low beams as a way to diagnose it if the issue continues.
Postby hockeydad4-22 » Tue Mar 20, 2012 8:25 am
socofn wrote:Got a short somewhere as I was driving home and 100yards from the driveway the headlights flickered and went out to come back on. OH boy I love this thing. JP
What Justin said. Had the same issue and replaced the switch - now they are all fixed!
Return to Chit Chat
Users browsing this forum: Google [Bot] and 5 guests
