Postby airbur » Tue Mar 20, 2012 10:32 am
Rox Crusher wrote:wholly crap batman................placed big order with WH
- all new floor pans
- steering column rebuild components
- tuffy concealed weapon lockbox
- EB classic tachometer set up
Those lockboxes are sweet...I want one. I can't see it being useful as a concealed access point though. By the time you get into it and retrieve anything, it'd be a bit to late.
airbur
Postby Viperwolf1 » Tue Mar 20, 2012 8:53 pm
I like the adjustable RS9000's on the back so much I decided to pick some up for the front today.
Postby crawlercreations » Sat Mar 24, 2012 4:49 pm
Finally got my front bumper done! Still have to bolt the winch on. Also installed new my new front fenders. Still a bit to go but it is coming along.
crawlercreations
Postby 99f250 » Sat Mar 24, 2012 7:44 pm
Awesome bumper!
99f250
Postby 99f250 » Sat Mar 24, 2012 7:45 pm
Got the wild horses roll cage handles put on...disc brake kit should be here Monday
99f250
Postby Kinder » Sun Mar 25, 2012 7:29 am
Replaced pass side D44 axle. Note to self: stay out of Bronco sized mud holes.
Postby rdanford » Sun Mar 25, 2012 7:42 am
Got the rebuilt 3rd with 4.10s and rebuilt axles installed...wow, the new power is great
Royce
2006 4Runner V8 Sport Edition
rdanford
Postby TIM » Sun Mar 25, 2012 1:50 pm
for the past 3 weeks i've been working on replacing driver side kick panel, inner rocker, door post, rocker, fender, inner fender, floor panels.. and today I FINALLY got the doors alligned right (almost perfect) so now I can take out the self tapping screws and spot weld it all together... I'll be showing up to meet in a bronco by mid summer for sure.
TIM
Postby airbur » Sun Mar 25, 2012 3:47 pm
TIM wrote:for the past 3 weeks i've been working on replacing driver side kick panel, inner rocker, door post, rocker, fender, inner fender, floor panels.. and today I FINALLY got the doors alligned right (almost perfect) so now I can take out the self tapping screws and spot weld it all together... I'll be showing up to meet in a bronco by mid summer for sure.
Good progress! Hanging those damn doors is a PITA!
I got new(used) clutch fork spring installed. Then I spent 3 hours clay-barring my 4Runner....it's a pain in the butt but so worth it.
airbur
Postby Jesus_man » Tue Mar 27, 2012 12:39 pm
zillacon wrote:Damn EFI vapor locked again. Time to move the fuel lines off the top of the frame and to the outside.
Really? That's pretty unusual. Never had that problem, even in TX.
Postby Viperwolf1 » Tue Mar 27, 2012 2:10 pm
Dan, remind me what pump setup you have. Is it a BC in-tank pump?
Postby ZOSO » Tue Mar 27, 2012 3:43 pm
Id build a heat shield before goingthrough the hassle of moving the lines. My carb doesn't vapor lock....
Postby Entourage » Wed Mar 28, 2012 10:12 am
Which rear lunchbox locker did you guys do?
Postby Kinder » Wed Mar 28, 2012 9:48 pm
Powertrax No-Slip, picked it up from Off Road Ltd (they had a great price w/ mil discount), originally wanted to drop it into my old carrier but ran into a bearing size prob, hence a complete build.
Postby Gunnibronco » Wed Mar 28, 2012 10:37 pm
In between checking EFI codes, I fixed my horn. Had to put new aluminum tape behind the horn button on my Grant steering wheel. 14 years, and multiple disassemblies & reassemblies had damaged the contact surface. Still pretty wimpy, but at least it works. I need a real horn, like Zilla's.
Postby Jesus_man » Thu Mar 29, 2012 6:14 am
Zilla, I wish I knew you were keeping cooper. I have a little, and I mean a little here, so it's not worth it to me to take to the scrap yard. It's a U-shape from a defunct indoor fountain.
Be happy to give it to anyone.
Postby Jesus_man » Thu Mar 29, 2012 6:25 am
zillacon wrote:Depending on where you go prices right now are $3.25-$3.50 a lb for clean #1 copper so it pays to save it if you deal with it on a constant basis.
Absolutely! That's some good coin for sure! I may have 2-3 lbs in that one loop. Still not worth the special trip. But I guess I should find out where the recycler is. Maybe it's more convenient than I know??
Postby airbur » Sat Mar 31, 2012 4:18 pm
Started hearing a clunk every time I shut the driver's door. Cracked it open and found this....metal mounts both cracked off....
airbur
Postby Gunnibronco » Sat Mar 31, 2012 5:15 pm
Airbur, that looks very familiar.
Last night, I finally had enough confidence in my Bronco to drive it out to my friend's shop and have my tires swapped onto my "new" rims. Changed from Centerline HTIIs 15x10, to refurbed & repainted steel 15x8. Didn't go black, seems to be done a lot today, but went with a gray close to Audi bumpers. The new rims made the overall width a couple inches narrower, that is a good thing, since swapping to f/w axles, I felt like 1/2 the tire was hanging outside the flares. Still will end up with the wide flares from WH soon. The overhang sprays the side & inside of the truck with mud, snow, etc too much. Sorry the pics aren't great, by the time I took them the sun was setting and made it hard to get a good shot.
And she got a bath today. Since I have a facility dedicated to washing cars @ Avis, hopefully my fleet will stay cleaner.
Postby Rox Crusher » Sat Mar 31, 2012 6:10 pm
13 hour road trip to pick up Meyer snow plow which was supposed to be 6' but magically grew to 7' by the time we got there
Thanks Mike for doing the driving !
Postby Booger » Sat Mar 31, 2012 7:42 pm
Installed new header gasket on drivers side. It blew the whole back cylinder gasket out the last wheeling trip. Then washed it to get 3 wheeling trips worth of mud off.
My youngest grandson asked to go for a ride in papa's Bronco without the top. He saw a Jeep this past week with the top down and told his mama that he wanted to ride like that in papa's Bronco. So needless to say I removed all 3 windows and left it safari style. He came over and saw it and asked if we could put it down. Rob told him he'd get sunburned if we did so he was content. I had to put the back seat back in so me and him, daddy and sister could go for a ride. Took him to Jax so he could get a new pair of shoes. Watched him sitting in the back seat with a grin ear to ear the whole time. He and sister both had a ball.
Postby Entourage » Sat Mar 31, 2012 10:51 pm
Gunni - the rims look great.
Postby D&D72 » Sat Mar 31, 2012 11:43 pm
Rox Crusher wrote:13 hour road trip to pick up Meyer snow plow which was supposed to be 6' but magically grew to 7' by the time we got there
that needs to be on the "know what sux" thread. did you pick it up anyway?
D&D72
Postby Rox Crusher » Sun Apr 01, 2012 2:42 am
yup, it will be fine
Postby Gregg » Sun Apr 01, 2012 8:01 am
I swapped out my old tranny cooler for a 96 explorer cooler. The old one was mounted on the underside of the radiator but i moved the newer one up in front. I'm not sure how I will notice any difference (other than not smashing it on a trail).
I also pulled the rear axles and dropped the third member. I'll be taking it to that dude in Erie and he'll build me a 4 pinion Limited slip. While he's working on that I'll be putting in new seals, picking up my sissy pink coffee cup (and asking Dan to press on some axle bearings), pulling and putting in new axle seals, wheel cylinders and rebuild the drums.
cool.
Update: I soldered the radiator tube from the tranny cooler mishap. works good so far but really wont test it until the center / axle / drums, are back together.
Gregg
Postby Kinder » Sun Apr 01, 2012 9:11 am
Wow, huge upgrade. Your rear end will be in great shape after all that...
Postby Entourage » Mon Apr 02, 2012 10:49 am
I had a great weekend. I added carpet kit (thanks Landshark), insulation, roll bar dome light, fastened my interior panels (thanks JGZ), wired CB antenna, fire extinguisher.
Postby hockeydad4-22 » Mon Apr 02, 2012 11:13 am
Cool! Looks good Chad. Is that dome light hard wired or battery operated?
Postby Entourage » Mon Apr 02, 2012 11:22 am
It is battery powered with 5-bright LED lights and run on 3 AAA Batteries from Rampage on Amazon.com for $15.00 - 60 second install. Even has a magnet if ya wanna stick it instead of the roll bar mount.
http://www.amazon.com/gp/product/B0046K ... 00_details
Postby Justin » Mon Apr 02, 2012 4:10 pm
Looks really good! Not to be the safety nazi (again), but how much clearance is there between the extinguisher and the rear seat occupant? It looks like it could rotate around the bar and smack that passenger in the head in a high speed impact.
Return to Chit Chat
Users browsing this forum: Google [Bot] and 8 guests
