Pinion Guard Install
Postby pgilbeau » Wed Oct 21, 2020 9:23 pm
I haven't messed with my 9" center section except for putting it in and taking it out. I want to install a Ruff Stuff pinion guard but not sure if I can just pull the bolts and put the guard on or will I need to set the gears back up after pulling the bolts and installing the guard.
https://www.ruffstuffspecialties.com/9F-PIN.html
pgilbeau
Re: Pinion Guard Install
Postby Viperwolf1 » Thu Oct 22, 2020 8:17 am
No setup required. Might need longer bolts.
Postby pgilbeau » Thu Oct 22, 2020 8:26 am
Viperwolf1 wrote:No setup required. Might need longer bolts.
Thanks, just wanted to verify beforehand!
pgilbeau
Postby landshark » Thu Oct 22, 2020 10:05 am
confirmed, longer bolts are all that is needed
Postby pgilbeau » Thu Oct 22, 2020 5:32 pm
landshark wrote:confirmed, longer bolts are all that is needed
Thanks, time to get started on some stuff.
pgilbeau
Postby Rox Crusher » Thu Oct 22, 2020 6:14 pm
I installed the Duff version which is a nice piece
One thing I don’t like about any of these is that it makes using the center of the axle as a place to jack the axle up a bit unstable
Postby pgilbeau » Thu Oct 22, 2020 6:43 pm
Rox Crusher wrote:I installed the Duff version which is a nice piece
I just checked out the Duff version, seems to add more protection.
pgilbeau
Postby landshark » Fri Oct 23, 2020 11:10 am
Check out the Currie skid/pinion one. Pretty nice.
Postby pgilbeau » Fri Oct 23, 2020 8:06 pm
landshark wrote:Check out the Currie skid/pinion one. Pretty nice.
Is this the one? https://www.currieenterprises.com/CE-4303BSP
All I found was ones for the F9 housing.
pgilbeau
Postby landshark » Mon Oct 26, 2020 9:58 am
I think so, its the piece that bolts on. i know it fits the regular currie 9" as someone i know has one installed. To me its way too expensive - $240. The design seems like it would do a great job of protecting the the lip and bottom 3rd member better than anything else out there. Really its super simple and wouldn't be too bad to fabricate. I just decided to weld on some 1/4" plate to the bottom and back of the housing and used the Ruff Stuff Pinion guard.
I
Postby pgilbeau » Mon Oct 26, 2020 5:00 pm
landshark wrote:I think so, its the piece that bolts on. i know it fits the regular currie 9" as someone i know has one installed. To me its way too expensive - $240. The design seems like it would do a great job of protecting the the lip and bottom 3rd member better than anything else out there. Really its super simple and wouldn't be too bad to fabricate. I just decided to weld on some 1/4" plate to the bottom and back of the housing and used the Ruff Stuff Pinion guard.
It looks like a nice piece but the $240 is a lot of $. Probably going to go the same route, Ruff Stuff and weld on some plate but not sure yet. The Duff one is tempting but seems like it could possibly catch on stuff.
pgilbeau
Postby landshark » Tue Oct 27, 2020 8:21 am
Agreed - here are a couple of photos of what I did. I dont' have any of the bottom of the housing but its just 1/4" plate similar to the back bottom.
Postby pgilbeau » Thu Oct 29, 2020 3:47 pm
Thanks for the pic, probably going to do something similar.
pgilbeau
Postby Eck » Fri Dec 03, 2021 3:07 pm
Getting prepped to install the ruffstuff pinion guard at some point in the next while and was wondering about the bolt length. I did not order the bolts with the guard (didn't even think about it at that time). Can anyone confirm or recommend the bolts needed? From this thread it looks like longer ones are needed. Would rather get some at ACE than order from RuffStuff.
Postby landshark » Fri Dec 03, 2021 3:27 pm
I don't know the length offhand but you can get them at ACE no problem, thats what i did - assume 1/2" longer grade 8
Return to Chit Chat
