How to get donor Mustang off trailer
Postby tod » Thu Oct 29, 2020 2:44 pm
I found a great donor. 2019 Bullit. It is already on a trailer. All four wheels are trashed.
Any helpful ideas on how to get it off trailer and into the garage?
I also need recommendations for dollies to move it around the garage while I am dismantling it.Image
Sent from my SM-G975U using Tapatalk
1966 Bronco - 408 roller cam, Explorer serpentine, NV3550 5spd, hydroboost, 35s, 4.56 gears
tod
Re: How to get donor Mustang off trailer
Postby BroncoRaider » Thu Oct 29, 2020 3:25 pm
I love where this is headed.
BroncoRaider
Postby tod » Thu Oct 29, 2020 3:40 pm
Crested Butte
tod
Postby pgilbeau » Thu Oct 29, 2020 3:46 pm
I have had good luck with the Harbor Freight 1500lb Dollies.
https://www.harborfreight.com/2-piece-1 ... icle+dolly
Guessing it was put on the trailer with a fork lift. Does your trailer have ramps? If so I am sure you can find some way to get it down the ramps.
pgilbeau
Postby tod » Thu Oct 29, 2020 5:09 pm
Those dolly's should make it much easier to move once it is on the slab.
His trailer has ramps. They are heavy duty ladder style.
tod
Postby Viperwolf1 » Thu Oct 29, 2020 5:37 pm
I'd leave it on the trailer and cut away everything that isn't engine. If you take it off the trailer you'll need to find a way to get it back on when you're done.
Postby tod » Thu Oct 29, 2020 6:38 pm
Good idea about leaving it on the trailer.
Unfortunately the trailer is not mine. It belongs to my friend that is giving the Mustang to me, and he needs it for work.
Also, it has a lot of cool salvageable parts. Trick Brembo calipers and a really nice stereo that will work in Dad's 2019 GT that has an entry level stereo.
tod
Postby pgilbeau » Thu Oct 29, 2020 9:18 pm
I've done different things in the past to get salvage vehicles on and off the trailer, I usually always try and make sure they roll. That looks like the best it could get is the rear rolling. Don't know if you have access to one but I have used the winch on my Bronco to pull a vehicle off my trailer and down the ramps. Maybe if you put something over the ramps to make it smooth it could be dragged off.
pgilbeau
Postby Rox Crusher » Fri Oct 30, 2020 5:49 am
how about hiring a tilt bed tow truck
drag it onto the tilt bed
have the tilt bed drop it where it needs to be
Postby landshark » Fri Oct 30, 2020 7:40 am
Truck with a strap if both rears will still roll but probably mess up the trailer deck. Maybe some kind of skid plate (4’x8’ sheet of steel?) under front and then pull it off.
Postby mickphatmac » Fri Oct 30, 2020 8:39 am
Well I think the obvious answer is Forklift...But where to get one!???
Images: 14
Postby mickphatmac » Fri Oct 30, 2020 8:41 am
BroncoRaider wrote:I love where this is headed.
Crested Butte... :laughing2:
Images: 14
Postby ManTruck » Fri Oct 30, 2020 10:00 am
Backhoe from rental place. Put it where you want it.
Owned my 1972 since 1985
Canon City, Co
ManTruck
Postby tod » Fri Oct 30, 2020 10:24 am
Deciding on which BroncoImageImage
tod
Postby ManTruck » Fri Oct 30, 2020 3:00 pm
BOTH
Canon City, Co
ManTruck
Postby cdj7k » Fri Oct 30, 2020 5:21 pm
After seeing another post similar to this, i have been thinking you could strap some type of a ski (old snowboard?) to each corner that doesnt roll and slide it off. Might work better than just dragging.
cdj7k
Postby BroncoRaider » Fri Oct 30, 2020 7:51 pm
tod wrote:Deciding on which BroncoImageImage
I put seats out of a 2012 mustang in my ‘75. I REALLY like them. Very comfortable. They are a little tall though.
I’d put the Bullit drivetrain the EB, and then work with EFI Guy on the engine/transmission for the full-size.
BroncoRaider
Postby tod » Sat Oct 31, 2020 7:02 pm
Finally got it in the garage.
*Harbor freight dolly helped a lot.
*Hooked a winch to the tongue of the trailer and a pulley to the ramps and used that to pull it off.
*2x12s on the ramps.
*My wife's explorer winter wheels fit on the rear axle.
Thanks for the ideas.Image
tod
Postby pgilbeau » Sun Nov 01, 2020 12:06 pm
Glad you got it off the trailer and in the garage. Now the real work begins!
pgilbeau
Postby BroncoRaider » Sun Nov 01, 2020 3:29 pm
tod wrote:Finally got it in the garage.
And everyone here is now jealous of your garage space!
BroncoRaider
Postby tod » Sun Nov 01, 2020 4:22 pm
That was last winters project.
tod
Postby Jesus_man » Tue Nov 03, 2020 8:29 am
Subscribed!!
Postby tod » Tue Nov 03, 2020 6:39 pm
Good news. Charged the battery and it started instantly!!!
tod
Postby Jesus_man » Tue Nov 03, 2020 7:08 pm
Big Win! Now to make it all talk from under the hood of one of those broncos!
Postby tod » Fri Nov 13, 2020 6:58 pm
Making so.e progress on getting things stripped off.ImageImageImage
tod
Postby Justin » Fri Nov 13, 2020 9:05 pm
Progress! I like it! There's a stripper joke in there somewhere, but I'm too tired to find it.
Postby tod » Sat Nov 14, 2020 4:37 pm
Decisions need to be made.
My son's 96 Bronco has an old and tired 302/5.0. 5 speed manual.
My 66 has an almost new 408 stroker, roller cam, AFR heads, Carburetor. 5 speed - NV3550/ Dana 20.
Option 1: Put the Coyote in Brock's Bronco.
Option 2: Put the Coyote in my Bronco and the 408 into my son's.
Option 3: Open for ideas.Image
tod
Postby Jesus_man » Mon Nov 16, 2020 9:10 am
That's a tough call! It would be really sweet in either, but much more work to perform two motor swaps!
Postby mickphatmac » Mon Nov 16, 2020 5:10 pm
#2 please and ThankYou
Images: 14
Postby tod » Sat Nov 21, 2020 5:45 pm
Almost done stripping the donor.ImageImage
tod
Next
Return to Chit Chat
Users browsing this forum: Google [Bot] and 3 guests
