Justin wrote:I'm working on the same thing. Current plan is to add a resonator or bullet style Magnaflow upstream from the current Magnaflow, but I'm interested to see what everyone likes.
Justin wrote:Here's what I'm planning to put in: https://www.amazon.com/gp/product/B0018 ... 3240e894a8
Rob, interesting about putting it at the end of the exhaust. If I've got room, I might give that a shot.
I think crawler (Jason) is actually running two mufflers per side. Hopefully he’ll post up.ZOSO wrote:dang thats the shortest resonator ive seen. I might have to go with one of those also.
I know Crawlercreations has a quiet exhaust. Also JD's exhaust was quiet.
Kinder wrote:I think crawler (Jason) is actually running two mufflers per side. Hopefully he’ll post up.ZOSO wrote:dang thats the shortest resonator ive seen. I might have to go with one of those also.
Justin wrote:Nice! What muffler did you pick?
Justin wrote:Got my resonator put in. Found varying accounts of what works best, so opted to follow Rob's advice and put it as close to the end as possible. The system is shorty headers and 3" single pipe with a small, high flow cat right after the Y pipe and an 18" Magnaflow muffler. It's definitely quieter, but still has some solid rumble and the overall tone is both smoother and deeper. I lost a little of the crackle I loved while decelerating, but it's still there. At cruise, tire noise is louder than the exhaust. I'm still getting some resonance which I suspect is from the 3ft section of pipe between the cat and the muffler. For now, I'll leave it as is. Once it's linked I'll be re-lego-ing the entire thing anyway. Tomorrow it gets paint. Too shiny. I don't have a before clip, but here's the after:
https://www.youtube.com/watch?v=VA15jqa80bc
ZOSO wrote: Also JD's exhaust was quiet.
ZOSO wrote:sounds really mellow. mine had a crack to it when you snapped the throttle. which made it loud.
I did finally decide on a muffler. Going to order it up along with all my pipes and stuff. Waiting on the BC shorty headers to show up.
Justin wrote:Mine didn't seem to make much difference with noise, but I'm running a small, high flow cat. Fumes are 1000% better. Part of that is EFI, but the cat helps. Still getting a small bit of smell till the cat is hot enough to do anything.
TOOLMAN wrote: I did also change the tail to dump out the back like Chris's red one instead of the side. I got tired of dinging the pipe out the side on rocks! Seems to be a little quieter while on the road.
Justin wrote:I'll be going over the frame rail, down the outside of the frame, and out through the body once mine is linked. I could do it now except for where my shock hoops are located.
Gunnibronco wrote:TOOLMAN wrote: I did also change the tail to dump out the back like Chris's red one instead of the side. I got tired of dinging the pipe out the side on rocks! Seems to be a little quieter while on the road.
Off topic, sort of.
I'd like to see some pics of tail pipe locations out the back. When mine was there I had some trouble with dragging it while climbing steep obstacles.
I need to run my new exhaust and out the back would probably be my best route at this point but don't want to smash it flat again. I don't see a good route out the side due to my leaf spring location.
Users browsing this forum: Google [Bot] and 4 guests
