Register •
FAQ
• Login
It is currently Tue May 21, 2024 11:59 am
[ 6 posts ] |
BOBS 2 68S
Voltage regulator ?
Alt guage pegged to the charge side today coming home from Arvada. I changed the headlights and the guage cluster light bulb a fews bacK. Nothing else has been changed. Could the regulator be bad?
Sat Aug 07, 2021 2:26 pm |
Re: Voltage regulator ?
Did you check what voltage is actually at while charging? Still seeing 13-14v while running?
Sat Aug 07, 2021 3:51 pm |
BOBS 2 68S
So I went out to check things out and the battery is down to 11.5 volts and the regulator was warm. I have not driven it since yesterday.
Sun Aug 08, 2021 2:15 pm |
Sun Aug 08, 2021 3:35 pm |
I’d confirm the battery is in good condition before chasing volts, get a good baseline charge on it, battery should be showing 13+ volts fully charged, then load test it.
If the regulator failed while running for any amount of time it may have taken the battery with it.
Mon Aug 09, 2021 5:51 am |
BOBS 2 68S
The battery is a concern. I see what looks like battery acid splater on inner fender and hood. It did take a charge and with a new regulator from NAPA , I was able to start and the guage settled to "0" quickly. I drove it about 30 miles with it pegged at full charge.
Tue Aug 10, 2021 8:42 am |
[ 6 posts ] |
