Register •
FAQ
• Login
It is currently Mon May 13, 2024 3:46 am
[ 4 posts ] |
Radius arm extensions.I want to do this before Moab ANYONE?
trei75bronco
Joined: Wed Jan 26, 2011 10:55 pm Posts: 837 Images: 0
I really want to do a Radius arm Extention but I need help. I was lookind at Stone crusher but I hear they bend. I will buy there mounts maybe?? Maybe sleeve those stone crusher ones??? Trei
Sat Apr 23, 2011 7:57 am |
Re: Radius arm extensions.I want to do this before Moab ANYO
Sat Apr 23, 2011 8:13 am |
Definitely sleeve them if you are going to use the stone crusher extensions. Also, if you are still running stock bronco axle width you will run the tires into the arms hard if they are not bent. I rub my arms at full lock and I bent my custom arms quite a bit for clearance. If you just go longer they will get closer to the tires and will very likely limit your turning ability. Nice looking arms ZOSO! I asusme you don't have tire clearance issues due to being full width?
Another question to ask yourself....how many things do you want to bring to Moab untested? A lot it is probably fine as it has been done before by a lot of people BUT I always have a couple shake down runs before I decide to tow my Bronco far away. It would suck to rush through a project so you are done in time to make it only to have something screw up when you get there and ruin the whole trip.
Sat Apr 23, 2011 9:24 am |
Mine rub like crazy when trying to turn tight. But it doesnt bother me much as it still turns really good. Next on the list is cut off the stock bushings on the back and put on a ballistic joint. Mine bind on the droop side cause the rear bushings.
Sat Apr 23, 2011 9:33 am |
[ 4 posts ] |
Users browsing this forum: Google [Bot] and 13 guests |
