www.ColoradoClassicBroncos.com - View topic - Plug size
It is currently Wed Oct 09, 2024 4:24 am
Reply to topic  [ 10 posts ]
 Plug size
Post Plug size
In amongst my other issues i found that I have two different size spark plugs, larger on the drivers side. I will post pictures of the plugs side by side when the wife brings the camera home. Not sure why the PO did this. JP shrug
74, MONEY EATER
Wed Apr 27, 2011 6:24 pm
Post Re: Plug size
Are you sure they are different sizes or maybe just different brands/types? All be threads should be he same on the block.
Wed Apr 27, 2011 7:49 pm
Post Re: Plug size
Wed Apr 27, 2011 8:29 pm
Images: 1
Post Re: Plug size
Wed Apr 27, 2011 8:46 pm
Post Re: Plug size
Weren't there different size plugs required for some different years of heads? If so, wonder if this motor is running two separate years/styles of heads.
Wed Apr 27, 2011 8:51 pm
Post Re: Plug size
Different size (diameter) bigger around. Yes they were on the left/drivers side. The guy I bought it from had it for 6yrs and never did anything with it as he has a Moab special. I replaced the ones on the right side and re-gapped the other ones. I will buy replacements when I get a chance. No way it is running as both fuel tanks are lying on the garage floor. JP
74, MONEY EATER
Wed Apr 27, 2011 9:24 pm
Post Re: Plug size
My 68 302 4V head had larger plugs 13/16" than later models 5/8" I used to know this all by heart but have lost memory from many various brands of wobbly pops. more than likely someone changed a head out when another one was broken somewhere down the road.
Wed Apr 27, 2011 9:26 pm
Post Re: Plug size
That is what I kinda figured, someone along the line replaced a head. I will make it work till I can get the funds together to replaced the engine. JP
74, MONEY EATER
Wed Apr 27, 2011 9:30 pm
Post Re: Plug size
Yep, someone swapped a head. Early plugs were 18mm thread and later plugs were 14mm. The change was sometime mid-70's.
Wed Apr 27, 2011 9:58 pm
Post Re: Plug size
Wed Apr 27, 2011 10:19 pm
32,499,236 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
