Register •
FAQ
• Login
It is currently Fri Oct 04, 2024 3:11 pm
[ 7 posts ] |
Top Molding
Anyone put a weather strip or seal on the bed rails to protect the paint before installing hard top or soft top?
Wed May 18, 2011 8:21 pm |
BFD305
Joined: Sun Oct 10, 2010 11:33 pm Posts: 231 Images: 5 Location: Greeley, CO
Re: Top Molding
Ours has the factory seal. Still had some marks when it was removed, but it had been on for 25+ years.
Wed May 18, 2011 8:44 pm |
Re: Top Molding
You might consider ordering some rubber strips from mcmaster. That would both protect and seal.
Thu May 19, 2011 9:01 am |
Re: Top Molding
I have not checked with mcmaster - great idea!
Thu May 19, 2011 9:03 am |
Re: Top Molding
I needed some to space the top away from the bedrails so my soft doors would fit. I ordered 1/4" thick, but you'd go with much thinner. And the softer stuff will crush better.
Thu May 19, 2011 9:13 am |
MARKNE
Re: Top Molding
would camper seal tape work ?? Has a peel back adhesive on one side, made out of foam rubber. Any RV place would have it.
Thu May 19, 2011 7:06 pm |
sbolt19
Re: Top Molding
watch out using neoprene, I have used it and it messes with the crush factor. The doors won't seal & you will have gaps all over the place. Get some really soft rubber or buy the OEM ones from JBG
Fri May 20, 2011 9:38 am |
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 1 guest |
