www.ColoradoClassicBroncos.com - View topic - Grant Steering Wheel specs
It is currently Thu Nov 14, 2024 10:06 pm
Reply to topic  [ 4 posts ]
Post Grant Steering Wheel specs
I have a 5 bolt steering wheel that may be a grant or grant knock-off. Before I order a horn button/kit for this could anyone with a Grant steering wheel give me a quick measurement?
Just want to know the distance from bolt to bolt and diameter of horn opening
Fri Dec 02, 2011 5:33 pm
Post Re: Grant Steering Wheel specs
mine is --
Bolt 2 bolt about 2 3/4" (on center)
the button is 1 3/4" with the bezel being 2 1/4"
-- ish !!!
Fri Dec 02, 2011 6:41 pm
I've got:
about 1 3/4 measured on center between bolts that are next to each other
Just shy of 2 1/4 for the hole in the center of the wheel without the bezel/button assembly installed.
Fri Dec 02, 2011 11:42 pm
Thanks guys. That'll work.
Sat Dec 03, 2011 1:59 pm
32,879,276 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
