www.ColoradoClassicBroncos.com - View topic - Another noob welding question
It is currently Sun Nov 24, 2024 9:47 pm
Reply to topic  [ 10 posts ]
Post Another noob welding question
I need to weld an O2 bung into my header and want to do it while I've got my floor pan out, making it really easy to access the header. I'm a total noob welder. How hard is it to weld something like this up and have it be airtight? After doing some reading I'm figuring on using the highest possible heat on my 110v welder w/.30 MIG or .35 flux core wire and overlapping a series of spot welds around the bung with a few seconds to cool between them. Any reason that is a terrible idea?
Sat Mar 10, 2012 12:30 pm
Post Re: Another noob welding question
Highest heat will burn a hole in it. Its no different than sheet metal. I've welded a bunch of exhaust and o2 bungs. Id start mid heat and adjust from there.
Sat Mar 10, 2012 2:06 pm
Sat Mar 10, 2012 7:12 pm
Put a old o2 or bolt in it so you don't hit rue threads. Buy two just in case. Happens to the best of.us
Sat Mar 10, 2012 8:48 pm
Much appreciated, thanks for the advice!
Sat Mar 10, 2012 11:50 pm
Sun Mar 11, 2012 1:44 am
Yep the threads are a 18mmx1.5 .
Sun Mar 11, 2012 8:01 am
Yea you could use an 18 x 1.5 nut for a bung as well.
Sun Mar 11, 2012 8:52 am
Sun Mar 11, 2012 9:01 am
i don't think so.Will have to look
Sun Mar 11, 2012 9:16 am
Users browsing this forum: No registered users and 64 guests
33,015,871 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
