Register •
FAQ
• Login
It is currently Fri Sep 20, 2024 9:20 pm
[ 8 posts ] |
what Spark plugs are you running
trei75bronco
What plugs are you running I have a302 with tbi [*]nomotor with torque r cam...seem to be runni.g a littrrich
Tue Apr 03, 2012 10:09 pm |
Re: what Spark plugs are you running
Next set I want to try are the E3's.
But for now, I think I just have a good name brand, but ordinary plug. Bosch maybe?
Wed Apr 04, 2012 7:28 am |
REH
Joined: Fri Oct 07, 2011 12:28 pm Posts: 56 Location: Cortez
Bosch or NGK, run from Champions,
Wed Apr 04, 2012 8:16 am |
cheap ol autolites in my 460. Havent had an issue yet. In my cobra I run cheap NGK's. You need to find the correct heat range and gap for your ignition system.
Wed Apr 04, 2012 9:27 am |
sbolt19
Autolites. I've tried all the high end stuff (had a friend who was able to get me platinums, split-fires, golds, and other high end plugs for dirt cheap) and they all ran like crap compared to the $0.99 Autolite plugs.
Wed Apr 04, 2012 9:31 am |
trei75bronco
I have a roller motor and duraspark ignition im autolite platinum .037 gap should I go.with a larger gap or smaller
Wed Apr 04, 2012 6:54 pm |
Hard to beat the good ol standby - Autolites. I used to use NGK in my 428CJ back when I was racing. They worked great, probably the best out at the time. Champion i would go through a set every few weeks. Tried Accel and others and still I kept coming back to Autolites. I've used Splitfire's on a few occasions and thought they gained a bit of mileage and power but I couldn't justify the price difference. E3's who knows, I've seen some good things about them but who knows.
Trei I think .037 should be about right.
Wed Apr 04, 2012 7:05 pm |
Wed Apr 04, 2012 7:09 pm |
[ 8 posts ] |
