Register •
FAQ
• Login
It is currently Fri Sep 20, 2024 11:47 pm
[ 7 posts ] |
how many degrees of timing are you running
trei75bronco
what is your timing I have duraspark .037 gap on plugs, torquercam , And im wondering wherr I should be
Wed Apr 04, 2012 8:26 pm |
Re: how many degrees of timing are you running
Start at 10* base and adjust from there.
Wed Apr 04, 2012 8:41 pm |
trei75bronco
I wanna say im at 12 but im a,tad rich
Wed Apr 04, 2012 8:58 pm |
Adding timing makes it run leaner. If your running rich not much an ignition system can do. Your running the bowelled correct?
Thu Apr 05, 2012 6:36 am |
sbolt19
Isn't base timing at 6? The way I learned was 1 degree for every 1000 feet in elevation, so depending on where you are in Colorado, you could be anywhere from 10 up. Here in the Springs, I always ran at 12 and never had a problem.
Thu Apr 05, 2012 9:48 am |
trei75bronco
I think.the tbi just runs a little rich
Thu Apr 05, 2012 12:43 pm |
Fri Apr 06, 2012 5:08 am |
[ 7 posts ] |
