www.ColoradoClassicBroncos.com - View topic - NEED HELP WITH Power Steering box assembly
It is currently Sat Sep 28, 2024 9:28 am
Reply to topic  [ 7 posts ]
Post NEED HELP WITH Power Steering box assembly
I tore me box down this weekend and drilled and tapped it for hydro assist steering, Its a Scout 2 box and everything I can find online id for inside the frame HEEPS. Viperwolf:) Please and help/info would be awesome. Trei 720-936-0791
Mon May 28, 2012 10:42 pm
Images: 1
Post Re: NEED HELP WITH Power Steering box assembly
call red neck ram .. good guys and im sure they can point you in right direction .. you want to do indy this weekend or 17th ?
Mon May 28, 2012 11:06 pm
If I get my stuff to do NY hydro assist. Helll yes
Mon May 28, 2012 11:11 pm
Met another ice racer that knows you
Mon May 28, 2012 11:13 pm
Sent you some instructions Trei. All the saginaw boxes are the same inside (except left or right turn) even if the outside is different.
Mon May 28, 2012 11:24 pm
Images: 1
staying on subject ,i run a scout box,,, bought a new shoot gun , you want to run out to golden gun club and shoot at some ?
Tue May 29, 2012 1:15 am
Images: 1
whats racers name ? its almost that time again .im already starting to look for tires to stud up.. you coming up this year ? ..do you already have ram?
Tue May 29, 2012 1:18 am
32,362,448 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
