It is currently Sun Sep 22, 2024 5:36 am
[ 5 posts ] |
HIX
Joined: Tue Feb 15, 2011 12:38 pm Posts: 174 Location: Wheat Ridge Colorado
rear seat on the cheap
For anyone else that had the same issue as me finding a decent rear seat the answer is a fold and tumble rear from a tj. With just a simple mod and a couple of holes you have a fantastic rear seat. I got mine for 50 bux.
Sat Nov 24, 2012 5:37 pm |
Re: rear seat on the cheap
I looked for a decent deal on one used for a few months before I just bolted in a stock Bronco rear I had given to me by someone at work. However, I am definitely interested in the TJ rear. Did you happen to snap some picks of the mods you did to make it fit?
Sat Nov 24, 2012 7:21 pm |
HIX
Just need to extend the pins 3 inches and make sandwich plates for the front mount
Sun Nov 25, 2012 11:32 am |
Colorado75bronc
Looks awesome!
Sun Nov 25, 2012 1:00 pm |
Yeah, that is nice. I've read it was a good swap, but hadn't seen pics.
Thanks
Sun Nov 25, 2012 4:39 pm |
[ 5 posts ] |
Users browsing this forum: No registered users and 16 guests |
