It is currently Mon Nov 25, 2024 3:32 pm
[ 10 posts ] |
Who wants to design a rotesserie?
I've talked about it often. Things always seem to get in the way. Work. Tiny garage. Sloped driveway. Well, now I wanna do it. I want to pull the body off the frame, and before/after that, I want to be able to suspend the body and frame, with no axles underneath. So, anyone have similar plans down the road and want to help design/possibly pitch in funds on a tub/tub-frame rotisserie? It doesn't even need to rotate. That's something we can hash out later.
Who's in?
Sun Apr 28, 2013 11:02 pm |
Re: Who wants to design a rotesserie?
Hmm, maybe buy one already done? I know of a guy who just re-built a '79 Bronco. I wonder if he'd sell his??
Mon Apr 29, 2013 7:22 am |
I'm game
Mon Apr 29, 2013 11:33 am |
I have a heavy duty cart that I built out of some of that shelving I was selling. It breaks down and I plan to put my tub on while I am doing the body work. Once I am done - I will be more than happy to pass it around the club for others to use at no charge.
Mon Apr 29, 2013 3:04 pm |
wanted to revisit this again as I have a few ideas that I want to get out of my head and on to digital paper. Things have a tendency to get lost in my noggin.
I was thinking of some sort of a gear and crank mechanism on one, or both sides, of the set up. Something that would allow a single person to easily turn the tub with possibly one hand. Obvisouly a pin of sort would also be required to hold the tub in a 90* position while floorboards, etc. are welded or worked on. Something similar in concept to the hand crank winches on a boat trailer?
Also, I was thinking interchangable forks. One set up for a tub with no frame. Another set up for a tub on a frame. Tub on the frame set up would be a short design, intended to go in to the frame rails. Could be a problem though for those frames with welded on bumpers, winch mounts, etc.
Fri May 17, 2013 1:17 pm |
It needs to be on a slider in the middle so stretch guys or wanna be stretch guys can play too.
Sat May 18, 2013 12:04 pm |
Zach - on the crank design, my Dad built an engine stand a long time ago. He used a fly wheel and starter gear for the mechanism. The starter gear was welded to the hand crank and the fly wheel to the spinning part. I don't recall what he used to hold it into position, but it worked well, even for big truck diesels. You could even modify the handle design to accept a drill for faster operation.
Mon May 20, 2013 12:30 am |
aaah1
Joined: Tue Feb 14, 2012 6:34 pm Posts: 74 Location: colorado springs
If I get bored this week, which i most likely will, I could put a design into solid works a modeling program. That could tell you how much weight it will hold, how big a gear would be needed to turn, and how much it will weigh, and my personal favorite how high u can drop it from.
_________________ 76 bronco, 351W, Zf, 6in of lift, 35x12.5 bfg all terrains
Mon May 20, 2013 6:07 am |
Cool, another CAD guy? I can draw pretty well on SW, but the analysis stuff is beyond me.
Mon May 20, 2013 7:29 am |
Crazyone
Joined: Tue Jan 25, 2011 9:33 am Posts: 207 Location: Aurora, CO
I had a friend of mine that built one out of 2 engine stands. It worked great for what he was using it for and it worked for any length. The only limit was weight but he did a couple of older Camaro's and some truck boxes with it. The great thing was he could change them back into engine stands when he needed them.
_________________ You will not see me cry because I do not sing the blues
Mon May 20, 2013 8:51 am |
[ 10 posts ] |
Users browsing this forum: No registered users and 91 guests |
