Register •
FAQ
• Login
It is currently Mon Nov 25, 2024 5:35 pm
[ 3 posts ] |
valentino
efi question
Do you have long or short headers with your efi and why?and if you have the long ones did you have any issues with the positioning of the oxygen sensors?
Fri May 31, 2013 9:36 pm |
Re: efi question
I used BCB shorties, because long tube (and my crappy old exhaust with stock manifolds) interfere with the front driveshaft with my high pinion front diff.
I can easily access my driver side O2 sensor, but my passenger side O2 sensor can only be accessed after removing my exhaust. Its squeezed pretty tight between my transmission and the body.
Fri May 31, 2013 11:08 pm |
Re: efi question
Had them both. Before the Atlas I had long tubes, but had to go mustang shorties due to lack of space.
Tue Jun 04, 2013 3:17 am |
[ 3 posts ] |
Users browsing this forum: No registered users and 112 guests |
