It is currently Sun Nov 24, 2024 2:59 am
[ 16 posts ] |
South Denver to Northern Co Springs Parts Shuttle
The Donkey express will be heading to Co Spgs on Thursday to do a disc swap and I'll be dropping of an axle IVO Palmer along the way. Does anyone need parts moved between these locales? I don't have an exact time yet, but I'll be running south in the morning and north in the evening.
Tue Mar 25, 2014 3:35 pm |
Re: South Denver to Northern Co Springs Parts Shuttle
akaFrankCastle has a set of gaskets for my 331 hemi. If you could grab them and bring them to Moab, that would be great.
Tue Mar 25, 2014 5:11 pm |
If you're able to grab the shock boots from Dirtheadz- I'd appreciate it. I can also bring Gunni's stuff to Moab for him if you pick it up.
Tue Mar 25, 2014 7:14 pm |
I need a couple little pieces of hardtop hardware from Zach if he is willing to part with them
On the inside of the liftgate there is a little rectang shaped cover where the spring loaded latches go into the hardtop. I need one in really good shape.
I also need the part(s) that go into the liftgate next to the latch mechanism. This lines up with the stub that is mounted to the inside of the tailgate and sticks into the spot on the liftgate I'm talkin bout when closed.
If you can figure out wtf I'm talking about from that crappy explanation, and Zach wants to sell them, and is around on Thursday.........then I will take em.
Many thanks !
Tue Mar 25, 2014 7:58 pm |
B.O.B.
Tue Mar 25, 2014 8:28 pm |
I'll coordinate with Zack and see if he can gets his parts together as well as grab the items from Dirtheadz.
Tue Mar 25, 2014 8:45 pm |
I'm in the woods until Thursday morning. I'll see if I can get everything together as soon as I get home and make link up with the Donkey.
Tue Mar 25, 2014 9:16 pm |
ClayJ
Stuff can be dropped off at my place any time Wednesday or Thursday. I'm going for a ride Wednesday afternoon but someone will be around
Tue Mar 25, 2014 10:07 pm |
Dirtheadz
Yep... Just give me a text/ call whenever. I can meet ya at Zack's or whatever works
Wed Mar 26, 2014 6:36 pm |
I should make it to Clays around 10 am tomorrow, if everything goes right it'll take less than 2 hours to get his brakes done. Dirtheadz, are you available to meet that early? Also I've lost your number, can you send it to me via pm?
Wed Mar 26, 2014 9:01 pm |
Gentlemen, my apologies. Work kept me late today and therefore I was unable to get Kirk your parts. I have been assured he will be back down next week, so I will make the appropriate preparations.
Fri Mar 28, 2014 12:46 am |
I was able to grab the shock boots, Zack and I will work out another meet up to get the rest sorted.
Fri Mar 28, 2014 8:37 am |
Rox, this correct? Or do you need both sides for the lift gate latch covers?
Sat Mar 29, 2014 10:36 pm |
Perfect !
Sun Mar 30, 2014 4:28 am |
Rox & Gunni, I've got the parts you requested. Gunni I also have a floor section for you and I'll coord delivery in the Moab thread.
Sat Apr 05, 2014 11:48 am |
Sweet, thanks.
Sat Apr 05, 2014 10:37 pm |
[ 16 posts ] |
