www.ColoradoClassicBroncos.com - View topic - Stump the Bronco Chump!
It is currently Sun Nov 17, 2024 6:30 pm
Reply to topic  [ 14 posts ]
Post Re: Stump the Bronco Chump!
Failed to tighten down the bolt on the dizzy clamp resulting in your timing slowly sliding off of mark until it finally failed to fire?
Wed Jan 05, 2011 6:18 pm
Throttle linkage came lose
Wed Jan 05, 2011 6:36 pm
was it the wire going from the dizzy to the coil?
Wed Jan 05, 2011 6:43 pm
Disconnected vacuum line? I dunno
Wed Jan 05, 2011 6:49 pm
Well it's electrical, I'll guess a main coming off the batt was loose.
Wed Jan 05, 2011 7:33 pm
coil gave up the ghost. I've had that happen.
Wed Jan 05, 2011 8:04 pm
Can we ask more questions? I'm wondering if it bogged down or if it was a straight up "peddle to the floor, no change in RPM" type situation.
Wed Jan 05, 2011 8:22 pm
you said it idled so carb and dizzy would have to ok , also a dead coil would kill it . points collapsing could cause this but don't know if it's electronic ignition . trans linkage going in neutral could do this if the bolt was loose .
Wed Jan 05, 2011 8:35 pm
If it was a points type dist.Was it the condensor?
Wed Jan 05, 2011 8:41 pm
Eddie Murphy is now working over at Exhaust Pros and he stuck a banana in the tailpipe ?
Wed Jan 05, 2011 10:29 pm
Images: 1
Carb linkage came loose/ plunger
Wed Jan 05, 2011 10:45 pm
Wed Jan 05, 2011 11:39 pm
Images: 9
Something with the elec. ignition control
Thu Jan 06, 2011 2:18 am
That happened to me this last summer on my 57 t-bird.Drove me flippin nuts!Same sort of deal,would idle all day,had all new parts,go to drive it and it would fall flat on it's face.I even had one of my mechanic buddies who's been working on hipo fords for as long as I remember take a look at it and it stumped him for awhile,so I didn't feel like such a moron.He said that's the first time he's ever seen that.Probably stupid chinese parts.What a pain in the ass!Glad you got it figured out
Thu Jan 06, 2011 9:39 am
32,893,538 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
