Register •
FAQ
• Login
It is currently Sun Sep 29, 2024 7:18 am
[ 4 posts ] |
Trailer or flat tow behind motorhome ?
Angie and I have decided to get a Class C motorhome next spring as her back problems don't allow her to enjoy all the glories of sleeping on the ground in a tent.
Planning to take at least a couple trips per year with the Bronco in tow and wonder if I should flat tow or bite the bullet and get a short trailer.
I have already eliminated a car dolly from consideration as I'm not even skilled enough to back them up using my truck.
Let's hear the pros and cons of flat towing vs trailering ?
Mon Aug 18, 2014 7:43 am |
pony boy
Joined: Fri Jun 29, 2012 11:42 am Posts: 54 Location: 9000 ft MT ROSALIE ( BAILEY )
Re: Trailer or flat tow behind motorhome ?
trailer for me!!!! 2 axle easier backing and more stable if not loaded right!!! does not sway as easy as a single axle. and can be towed by bronco to use for other things. pulling the bronco u should pull the rear drive shaft + all the wear on the broncos tires bearings and suspension. an 16" or 18" 2 axle flat bed or car hauler duel brakes get a good electric brake controller. DOT will tell u 1 brake is good enough but 2 is way better and should not be more than 200.00 to ad.when running hills the second set will stop u were 1 will not after heating up. i sold trailers for 25 years in Colorado sold road runner out of Mississippi all trailers i brought to Colorado had duel brakes. hope this helps pony boy
Mon Aug 18, 2014 11:57 am |
I recommend a lift on the motorhome before you hit the trails with it.
Mon Aug 18, 2014 9:31 pm |
Tue Aug 19, 2014 2:46 am |
[ 4 posts ] |
