It is currently Sun Sep 29, 2024 1:29 am
[ 12 posts ] |
Unaweep
Making Round things
Hey - I'm thinking about buying a used plate roll to roll steel, thin steel. 3 roll initial pinch. Durma 1202. The capacity of the machine for steel is 14ga X 4ft, it's powered by a 1hp motor. The minimum diameter of a cylinder roll would be about 10", no max dia. Any idea's for something to build for the Bronco? I gotta play around with it - as rolling is a art + science. Here's a link if you've never seen one: https://www.youtube.com/watch?v=j6BNa84KURQIdea's? J.E.
Sat Sep 06, 2014 2:32 pm |
cpldavis37
Re: Making Round things
Custom fender flairs!
Sat Sep 06, 2014 4:42 pm |
Gigantic inner fenders.
Sat Sep 06, 2014 5:04 pm |
Old school fuel cell
Sat Sep 06, 2014 6:36 pm |
Unaweep
ok, that's some idea's. Old skool fuel cell seems the easiest.
J.E.
Sun Sep 07, 2014 3:47 pm |
Colorado75bronc
Ya a moon tank would be awesome! Air tank if you could do it out of thicker material.
Sun Sep 07, 2014 5:40 pm |
I tube/pipe roller would come in more handy I would think.
Mon Sep 08, 2014 7:18 am |
Unaweep
Tue Sep 09, 2014 11:42 am |
I understand, but I'm thinking you're money would be better saved and put towards that pipe roller.
Tue Sep 09, 2014 12:38 pm |
Unaweep
Jesus man - I think your misunderstanding me.
The plate roll is for a project at work, but I need to practice using this one and thought "What can I make for the Bronco?"
J.E.
Tue Sep 09, 2014 5:00 pm |
Ahh, indeed I did.
What about making replacement rockers?
Wed Sep 10, 2014 1:57 am |
Dirtheadz
I stayed at a Holiday Inn & have messed around a little with fabrication.... I would love to have a roller. Keep your mind open when tinning. Mix it up with rolling, utilizing a straight brake and even bead roller to make your projects. People seem to forget that.
Wed Sep 10, 2014 7:10 am |
[ 12 posts ] |
