It is currently Thu Sep 19, 2024 6:42 pm
[ 13 posts ] |
Hydraulic Press ?
Does anybody know of or have a hydraulic press that is capable of pressing wheel studs into an axle flange ?
Sat Oct 18, 2014 2:28 pm |
Re: Hydraulic Press ?
I've got one you're welcome to use.
Sat Oct 18, 2014 3:06 pm |
BFH
Sat Oct 18, 2014 4:05 pm |
phyler
Funny, I have to do that tomorrow and was planning on the BFH method.
Sat Oct 18, 2014 4:34 pm |
BFH didn't get it done.
Nor did a 20 ton hydraulic press.
I'm quite sure the holes in the axle flange are undersized for the wheel stud which I know to be the correct size.
Sat Oct 18, 2014 6:45 pm |
You're not supposed to weld them in.
Sat Oct 18, 2014 7:53 pm |
ManTruck
I'm sure you know this but I usually help my pressing by heating the axel or receiving part and freeze the pressed in piece prior to the instal. Seems to make a difference in what I break or don't break.
_________________ Owned my 1972 since 1985
Canon City, Co
Sun Oct 19, 2014 5:47 am |
Colorado75bronc
Hydraulic Press ?
If you can't press in wheel studs than something has to be wrong, wrong studs, they should be able to be knocked out and in with a hammer
If you have an old one out, measure it with a vernier caliper or mic on the splined area, should be within a couple thousandths, the new should be just a little larger than the old .0005-.002" maybe 3 thousandths
Sun Oct 19, 2014 10:49 am |
The studs came with the rear axle assembly for the kids Crown Vic Cop Car.
I'm thinking the holes are undersized, but I suppose it could be oversized wheel studs just as easily.
We are bringing the whole shebang back and exchanging them for another version of quality chinese parts.
Sun Oct 19, 2014 11:51 am |
Orielly's rounded another up for us.
Holes were slightly larger than the ones in the the hacked up one, but still not big enough for the studs.
Nobody else has one so will probably go to the p-n-p next week end.
Sun Oct 19, 2014 5:24 pm |
Gregg
OOOOOOOOOOOOh! Now you want to go to the PnP.
You don't need special tools. You just have to be crafty. Remember my homemade press? bubba tech2.jpg
Mon Oct 20, 2014 11:11 am |
Dukietown
Mon Oct 20, 2014 2:03 pm |
Still waiting for that LIKE button!!
Mon Oct 20, 2014 3:19 pm |
[ 13 posts ] |
