www.ColoradoClassicBroncos.com - View topic - Easy height measurement needed
It is currently Tue Nov 05, 2024 11:30 pm
Reply to topic  [ 9 posts ]
Post Easy height measurement needed
Hey guys, since I'm going to rework my suspension and have NOT made any decision yet on how much lift to go with, could I get a height measurement?
Ground to bottom of door handle inches is what I'd like.
Let me know your tire size, lift " and if you have a body lift.
I currently have some suspension lift but it's a homemade with a 74-75 front disk brake front end.
Thanks.
Erik
Sun Apr 12, 2015 8:48 am
Post Re: Easy height measurement needed
49" to the bottom of the door handle (not button).
I have a 3 year old WH 3.5 SL. No body lift with some pretty old body bushings. 33" BFGs
2" to spare on garage door.
Sun Apr 12, 2015 2:04 pm
52" on BSD, 3.5" linear Deaver coil springs, old school 3.5" Duff leafs, 2" poly body lift on rubber body mounts. 35x12.5x15 KM2's w/ half the tread left.
Sun Apr 12, 2015 2:42 pm
52.25" on the 69. 3.5" Duff coils and leafs. 3" body lift. 35x12.5x15 km2 with 80% or so tread left.
Sun Apr 12, 2015 7:26 pm
49.5" on the 1/2 cab 3.5 inch suspension lift and 1 inch poly body lift.
New 33x12.50x15 tires
52 3/4" on the 74 with 5.5 inch suspension lift no body lift.
New 37x12.50x17 km2 tires
Mon Apr 13, 2015 9:45 am
Sounds like my custom suspension is lower than I thought. I was thinking 4.5" suspension with no body lift and true 37" Iroks but I'm at 50.5" to the bottom of the door handle. Looks like I'm closer to 3.5, or so, of lift based on what I'm seeing here.
Mon Apr 13, 2015 5:05 pm
Thanks for the replies, I'm not sure what I got now, my Bronco is 46.5" to bottom of door handles with 33" tires (new Goodyear Duratrac's).
I wonder is its stock or a saggy ole 3" suspension. I thinking I may go 4.5" suspension on the rebuild.
edit: Does anyone know what a stock Bronco measurement is?
Erik
Mon Apr 13, 2015 5:49 pm
Very few stock suspension Broncos rolling around. Zack, Clay & Jeremy are probably going to give you the best measurements for that.
Mon Apr 13, 2015 8:31 pm
College. I hate writing papers. I'll try and grab a measurement from TO in the morning before I leave. Although, I have no door handles.
Mon Apr 13, 2015 10:18 pm
32,794,532 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
