www.ColoradoClassicBroncos.com - View topic - What size conduit to garage for 100amp service?
It is currently Thu Oct 31, 2024 8:21 pm
Reply to topic  [ 8 posts ]
Post What size conduit to garage for 100amp service?
What size conduit do I need to run to make it relatively easy to pull 100amp service wiring through? Figuring 2" with two 90 degree sweepers. May not pull the wiring until next year when I redo my garage but have construction crew digging up the yard and wanting to lay the conduit now.
Also heard I can't run other wiring in the same conduit as the service line so probably should run another 1 1/4 line as well for lights and anything else I want to control from the house?
Thu Jul 14, 2016 2:31 pm
Post Re: What size conduit to garage for 100amp service?
I'd suggest running a separate conduit for speaker wires so you can have outdoor speakers with no interference. May as well while you can...
Thu Jul 14, 2016 2:33 pm
I don't know the answer. It has to do with the % of the conduit filled by the line. I did direct burial cable to my garage, no conduit.
Thu Jul 14, 2016 2:40 pm
Thu Jul 14, 2016 4:21 pm
My buddy had this to say on the conduit for the 100amp.
It depends on the wire size. I suggest an 1-1/4" SCH 40 PVC.
Thu Jul 14, 2016 5:13 pm
Go with 2in. It's overkill but will make pulling the wires in easy. And an 1 1/4 for lighting and such will be more than enough.
Thu Jul 14, 2016 8:50 pm
I just buried the power out to my garage a month ago and the electrician did 1-1/4" because I told him I wanted 220v out there someday. And then I ran an extra 1-1/4" for other stuff: coax, sprinkler wire, whatever...
Fri Jul 15, 2016 7:06 am
Cool thx for all the info. Iam going with 2" for service and 1 1/4 for extras
Fri Jul 15, 2016 8:03 am
Users browsing this forum: No registered users and 10 guests
32,734,167 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
