www.ColoradoClassicBroncos.com - View topic - transmission and transfer case questions
It is currently Sun Nov 24, 2024 12:49 am
Reply to topic  [ 4 posts ]
Post transmission and transfer case questions
When I installed the transmission and transfer case the cross member bolts were broken off or stripped out. With that said I Pulled a Stupid and had the cross member welded in. Now the original 3 speed is giving me problems so I have a few questions before I jump in head first.Will be switching it out the 3 speed for a NP435 and D20 T- shift transfer case. Was going to order thru TBP or JBG.
Any thoughts about what rebuild kit I should get ?
Also how would I go about the cross member cut out the bolts and have a new piece welded in or maybe try going to a bigger bolt and re-tap the holes ? Those were the only things I can think of.
Need lots of ideas besides rolling it down the hill. HAHAHA
Sun Oct 09, 2016 4:42 pm
Post Re: transmission and transfer case questions
If you only welded the angle brackets to the frame and not the cross member to the angle brackets it's not a big deal. The 435 is very close to the length of a stock 3 speed so the angle brackets won't need to move.
If you want to fix the holes for the angle brackets I would use nutserts.
Sun Oct 09, 2016 10:54 pm
nutserts or you can drill out and weld flange nuts in with the flange as your weld area against the frame (make sense?).
Mon Oct 10, 2016 7:19 am
Thanks guys. I really appreciate it. I only had the angle brackets welded on. So I might not have screwed up as bad as I thought. Never heard of a nutserts but I do understand what your saying.
Mon Oct 10, 2016 5:51 pm
32,987,195 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
