It is currently Sat Nov 23, 2024 10:50 pm
[ 9 posts ] |
casadejohnson
Broken window
So, most everyone at the Platte River grill Saturday listened as my drivers door glass shattered upon closing the door. As it turns out, the rear window track which is only a few months old failed allowing the window to swing freely in the door. I believe it hit the rod for the door latch and now it sits in the bottom of my door in thousands of tiny pieces. I thought I had an extra door glass in the hoard of parts but my garage search tells me I don't. I believe Chris said he had a spare as well as a few other folks. If any of you have had a chance to check your parts piles and have found door glass that you can part with let me know. The broken window was a drivers side but I can make a passenger side window work by flipping the track around. Any help is appreciated
Mon Oct 10, 2016 12:36 am |
Re: Broken window
I do have an extra one Iam swapping doors at some point and can just reuse the current one in the bashed up door. Let me know.
Mon Oct 10, 2016 11:04 am |
Re: Broken window
I found one for him in storage.
Mon Oct 10, 2016 4:15 pm |
Re: Broken window
New window track or new to you?
Mon Oct 10, 2016 6:31 pm |
casadejohnson
Re: Broken window
Mon Oct 10, 2016 9:38 pm |
Re: Broken window
Mon Oct 10, 2016 9:39 pm |
casadejohnson
Re: Broken window
Thanks to Phil for scrounging me some glass out of his secret bronco stash
casadejohnson
Re: Broken window
If I recall I got it from Tom's. Not sure who makes it as it came without any manufacture info.
Mon Oct 10, 2016 9:42 pm |
Re: Broken window
Mon Oct 10, 2016 10:29 pm |
[ 9 posts ] |
Users browsing this forum: Google [Bot] and 6 guests |
