[phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4794: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4796: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4797: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4798: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) www.ColoradoClassicBroncos.com - View topic - Silicone radiator hoses
I put silicone radiator and heater hoses with the wide recommended clamp. I have to tighten them almost every time I drive the bronco. Has any one else tried them or had the same problem? I will get 2-4 full turns on most of the clamps. I almost ready change back to oem parts.
Sat Nov 04, 2017 5:14 am
horseplay
Re: Silicone radiator hoses
I have them on my truck with no problems at all. I'm using European style narrow width hose clamps I find they don't cut into the hoses and damage them as much.
Sat Nov 04, 2017 9:59 am
Moab Mike
Switch to a spring loaded clamp like the oem style. No more worm clamp issues.
Users browsing this forum: No registered users and 14 guests
