www.ColoradoClassicBroncos.com - View topic - Airbur's 427W Build Thread
It is currently Tue Oct 01, 2024 5:30 am
Reply to topic  [ 386 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 13  Next
Post Re: Airbur's 427W Build Thread
Dang, it must be nice to finally be able to put the timing chain assbly on!! What compression ratio are you hunting for? Looks like 26cc or close to it, dish pistons. I'll pm you my 4R70W shifter pics, not sure I can figure out how to post pics on the forum!
Sat Nov 26, 2011 11:09 am
10.63:1 on the compression. The pistons are very close to the deck height though so may need a larger head gasket.
They are 22cc dish pistons.
Sat Nov 26, 2011 12:58 pm
Stock heads
C90E-D 1969-1974 351W, 60.4cc chambers, 1.84/1.54 valves
C9OE-B 1969-1974 351W, 60.4cc chambers, 1.84/1.54 valves
10.59:1 is what I came up with guessing on your deck clearance
4.030" bore x 4.170"
.040" compr head gasket
4.050" gasket vol.
22cc dish
stock C90E head
Sun Nov 27, 2011 1:02 am
Haven't had a chance to run the #s but I am going with 185/58 AFRs, 2.02/1.6.
Sun Nov 27, 2011 1:07 am
Here's what I come up with....
Sun Nov 27, 2011 8:51 am
Isn't the head gasket thickness and head gasket bore switched in that screen shot?
Sun Nov 27, 2011 8:55 am
Sun Nov 27, 2011 9:03 am
A premium only motor huh?
Sun Nov 27, 2011 9:07 am
yep....that was expected.
Sun Nov 27, 2011 9:13 am
Do you have the 58 cc heads already? Comp or emissions legal? The 185 comp heads flow within 6 cfm or so of the 205's and for our application (according to AFR techs) they will still have the same port velocity at low-mid range rpm for max torque. I'm planning on going with the #1383's. You can mill .006" for every cc on that head to dial in your compression ratio.
lot's of options...they just all take away from beer and cookin
back to the shop...
Sun Nov 27, 2011 1:08 pm
Sun Nov 27, 2011 1:27 pm
So I did some figuring, and with my current 58cc heads here's the new calculation. I also did it with those larger heads and the compression dropped to 9.26....how would that affect power?
http://www.gtsparkplugs.com/CompRatioCalc.html
I ordered the timing cover and water pump today.
Sun Nov 27, 2011 6:06 pm
20% off the order plus a $50 gift card:)
http://shop.advanceautoparts.com/webapp ... nt=general
Sun Nov 27, 2011 6:09 pm
Dang purdy looking...Exploder front dress?
I did some head milling figures and if you cut the 72cc heads to 64 then you'd drop to 9.95:1 compr. I haven't talked to the AFR tech guys about milling that much off, but taking them to 66cc wasn't an issue. They'll mill them at their factory for $100
Not sure I'd bump up the compressed gasket thickness much. It will really affect your quench if you get too high. That will also affect your cyl burn and timing, etc.
You don't lose much hp by reducing your CR. Performance Trends Engine Analyzer thinks when raising the compression ratio from 9 to 10, it thinks that HP will increase by appr 3.8% and torque improve by 2%. If I was going for ET's, that'd be one thing.
Just my .02, but try to get the compr ratio down to a number you can run on pump gas anyway. With all the power you'll have under the hood, you aren't going to notice 18HP difference! : )
Sun Nov 27, 2011 10:21 pm
Thanks for the info. I thought I had this figured out....but I don't. Found a great article on compression and pump gas....
http://www.popularhotrodding.com/engine ... ewall.html
Pretty technical but just how I like it.
When you say that AFR will mill the heads for $100 at their factory....does that mean you would send them in to AFR? Or would you buy them direct? Their prices are horrendous compared to the dealers (summit etc).
Just found a bit more info...from the AFR catalog on the #1383s.....(http://www.airflowresearch.com/27-31.pdf)
Angle Mill (10cc Maximum Optional Mill)-----------------------------------.008” per cc
Flat Mill (4cc Maximum Optional Mill)--------------------------------------.006” per cc
So that tells me we could get-er down to 62cc with an angle mill. At 63cc, that puts me at 10.03:1....I still need to recheck piston to deck height.
Mon Nov 28, 2011 7:04 am
Ok, so here's my latest calculations. I measured the piston to deck height at lunch and came up with an average of .009...talk about "zero decking" :). With that # and including milling the heads down to 64cc.....that puts me right at 10.06:1 compression.
Mon Nov 28, 2011 12:57 pm
now we're talking
HP and reliability !
Mon Nov 28, 2011 3:20 pm
You'll like these numbers a lot better! Every time you fill up!
Guys all the time talk about having to run max compression or your motor will be a dog...yeah, "a dog motor" at 9.8:1 compression only cranks out 500+ HP and 500+ft lbs of torque... : ) let me walk that dog!!! All on pump gas....nice...
Mon Nov 28, 2011 11:11 pm
I'm going to talk with Scott at MPG Head Service and see if he can do the AFR milling...he's local and is the one that build my cam.
http://www.mpgheads.com
Last night I went through all my research on the bolts needed for the Explorer serpentine, water pump, and timing cover. I went to Ace and they didn't have any of the odd lengths so I did up an order with Fastenal. They have everything except the one 5/16-18x3/16 bolt so I'm going to try a 1/4.
Tue Nov 29, 2011 7:28 am
Tue Nov 29, 2011 8:37 am
So here is the new timing cover I got from AdvanceAuto...it's a Dorman model. Crap.....guess it's off to the junkyard again.
Wed Nov 30, 2011 7:11 am
The new timing cover (ATP brand) and water pump arrived today. Both in perfect condition. Waiting on the bolts for the serpentine and also the windage tray and bolts.
http://www.amazon.com/ATP-103039-Timing ... 426&sr=8-1
Fri Dec 02, 2011 7:56 pm
...still waiting... boardin
Sat Dec 03, 2011 10:38 pm
Sun Dec 04, 2011 8:41 am
Sun Dec 04, 2011 9:22 am
You learn good Grasshopper.
Sun Dec 04, 2011 9:30 am
Sun Dec 04, 2011 9:58 am
A full compression point drop- let's say 10:1 to 9:1 is appr 3% or so drop. At 500hp/500ftlbs torque (goal for most streetable 427 SBF stroker builders) you're not losing much for OUR uses... different story for ET's on the strip, you can't give up any of either.
An axle spline, axle eater is what he's building. icon biggin I don't know if Eric's locked solid front and rear but if he is, parts will twist... :)
I'm up to 35 spline alloys with pro-nodular Strange 9" now. I've twisted everything else off... burnout
save some $$ for upgrades :)
Sun Dec 04, 2011 7:46 pm
The axles are stock:) I plan to get this thing installed and then see what blows up (axle-wise). Then upgrade as necessary:)
Sun Dec 04, 2011 8:32 pm
Got some parts in today. Scoop, timing pointer, oil pump bolts.
Wed Dec 07, 2011 7:25 am
32,408,601 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
