EFI vapor lock....SOLVED!!!!
Re: EFI vapor lock....maybe
Postby Rox Crusher » Thu May 20, 2021 8:11 pm
Gregg wrote:Thanks Gunni and Eck. I wrapped the threads with the yellow tape and seems to be holding for now. No leaks.
Took it for a test drive around the neighborhood and it wasn't good. Lots of sputtering on acceleration. Idles fine.
32 psi on the fuel pressure gauge.
Yes, the hoses are hooked up correctly.
No kinks in the hoses.
Both pumps are getting power.
What else should I check?
Seems like it hasn’t been hot enough to be vaporlock.
How long does it hold the 32 psi after you shut it off?
Fuel filter location and condition ?
Postby cw72 » Thu May 20, 2021 9:15 pm
Throw a new fuel filter at it, I had the same issue when I redid my fuel system. Actually did a quick little “delete” just to see if anything changed as I drove around the block. (Probably not smart so do at your own risk I suppose) Sure enough it ran perfect so I ordered a serviceable one right then so I can pull and clean it out wherever I am.
cw72
Postby Gregg » Fri May 21, 2021 7:08 am
My set up is very similar to the pic Eck posted up.
Tank---NEW cheapo filter---LP pump----accumulator----HP pump---NEW filter---injectors---Return to accumulator---tank
32 psi and was at 22 psi an hour or so later
What's a quick little delete?
Eck-What post HP filter do you use?
Gregg
Postby cw72 » Fri May 21, 2021 7:13 am
Bypass the filter for testing purposes is what I meant. If the filters are both new that shouldn’t be the issue then. What cheap filter are you using?
cw72
Postby Gregg » Fri May 21, 2021 7:17 am
Gregg
Postby cw72 » Fri May 21, 2021 7:25 am
Good enough GPM and clear so you can see contamination probably rules that out.
You said you were EFI, do you have an fuel pressure regulator on the rail?
cw72
Postby Eck » Fri May 21, 2021 11:07 am
Gregg wrote:My set up is very similar to the pic Eck posted up.
I am using this one:
Edelbrock Pro-Flo EFI Replacement Fuel Filter
Part Number: 350-3596
https://www.jegs.com/i/Edelbrock/350/3596/10002/-1
Postby Gregg » Sun May 23, 2021 1:32 pm
I'm still having problems with sputtering and occasional backfire when accelerating or putting load on the engine (going up a hill). I tried going without the hp filter but that didn't change anything.
Primed and after the engine is off the psi is 40
Idle psi is 34
Before I go after the injectors is there a way to test the pressure regulator?
Gregg
Postby Eck » Sun May 23, 2021 1:46 pm
https://axleaddict.com/auto-repair/How- ... -Regulator
A new FPR is about $50 at O’Reilly’s.
Postby Gregg » Sun May 23, 2021 2:21 pm
FPR passed the tests. Thanks for the link.
Gregg
Postby Kinder » Wed May 26, 2021 5:59 am
Jog my memory, this is a stock tank with the factory pickup/sending unit right? You might consider pulling the pickup out and confirming the “sock” isn’t falling apart and plugging the pickup.
Postby Gregg » Sat May 29, 2021 4:12 pm
Quick Update:
I pulled the upper intake and got to the injectors. I soaked, cleaned, tested, and blew them all out. I ordered a rebuild kit and put it all back together. No change. Idles fine but sputters on acceleration or load.
I had a spare hp pump so I threw that in and it ran the same as with the other pump. I guess I could through a new FPR at it but I'm guessing it won't change anything.
Primed psi is 34ish
Idle psi is 34ish
With Engine off it holds at 40 psi for awhile.
Not a stock tank but an older 22 gal (thanks for chimng in Kirk)
Anything else guys can think of?
Thanks.
Gregg
Postby Gregg » Thu Jun 03, 2021 8:42 pm
I replaced the FPR with a a new one and it didn't change anything. I'll post up on CB.com and get a few more opinions. Feel free to chime in if you have any thoughts.
Thanks guys!
Gregg
Postby Rox Crusher » Thu Jun 03, 2021 8:52 pm
Perplexing
Postby mickphatmac » Fri Jun 04, 2021 7:04 am
did you check your timing?
Images: 14
Postby Gunnibronco » Fri Jun 04, 2021 7:06 am
I'm just stabbing at this, but could it be a dirty mass air sensor or bad TPS?
Postby Viperwolf1 » Fri Jun 04, 2021 11:37 pm
I don't remember, is this mustang or explorer EFI? If it's explorer you can't change the timing.
Postby mickphatmac » Sat Jun 05, 2021 6:55 am
Viperwolf1 wrote:I don't remember, is this mustang or explorer EFI? If it's explorer you can't change the timing.
AHHHaaaa!!! did not know that!?
Images: 14
Postby Gregg » Sat Jun 05, 2021 2:16 pm
mickphatmac wrote:did you check your timing?
No. I thought the explorer computer adjusted that....
Gregg
Postby Viperwolf1 » Sat Jun 05, 2021 3:11 pm
So this is explorer efi? Coil packs and no distributor?
Postby Gregg » Sun Jun 06, 2021 9:46 am
It "was" a mustang efi but we swapped it over to the explorer harness and coil pack a few years ago.
Oh, I changed my air filter and cleaned the MAF a couple months ago
As for the TPS---if it were faulty, would it sputter if I rev -ed it in park/neutral. Only asking because when I rev it in neutral it sounds / responds great.
Gregg
Postby Viperwolf1 » Sun Jun 06, 2021 10:08 am
Well the good thing about the explorer EFI is you can hookup a good scanner and look at all of the sensors while they are working. You can also see if it has any codes stored. I might know a guy with a scanner.
Postby Gregg » Sun Jun 06, 2021 11:03 am
Is it close to " Larry the Cable Guy"?
I videoed the FP gauge driving around the hood: idles at 36 psi and during acceleration it'd go up to 40-41 psi. I figured the FPR knows what its doing but could there be too much gas and bogging the engine down?
Gregg
Postby Viperwolf1 » Sun Jun 06, 2021 1:03 pm
Gregg wrote:Is it close to " Larry the Cable Guy"?
More like Kevin the scanner guy.
I think your fuel is fine at this point. Need to start looking at other things. Burnt plug wires maybe?
Postby Gregg » Mon Jun 07, 2021 3:05 pm
Looks like I owe Phil a case of :beer: Corona :beer:
Cylinder #5 wire looked suspicious. I checked the resistance and it was clear that nothing was getting through. The wire looked okay but inside the boot was really corroded. I cut the wire above the boot (tested it again with an acceptable reading) and replaced it with my spare boot/crimp. It actually ran slightly worse so I cleaned the spark plug terminal (also corroded) and that was it. Back on the road for now.
I thin k it was corroded because my PS reservoir is making a mess of anything that touches it. The coating on the wire was looking rough so I'm guessing the PS fluid made its way down to the boot...Time to get more spare boot/crimps.....
I love fixing one thing while another thing unknowingly fails and f**ks up the whole trouble shooting process. Nice catch Phil. Thank you!
Gregg
Re: EFI vapor lock....SOLVED!!!!
Postby TOOLMAN » Mon Jun 07, 2021 3:41 pm
Nice! Now can we move onto other things? icon biggin
TOOLMAN
Previous
