www.ColoradoClassicBroncos.com - View topic - EFI conversion questions - lots of random ones
It is currently Sat Nov 23, 2024 7:28 am
Reply to topic  [ 222 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 8  Next
Post Re: EFI conversion questions - lots of random ones
I grabbed my dizzy to look at taking it apart & remote locating the TFI. That ended pretty quickly, I'll go check with a mechanic on Monday to get the special f'n tool.
I realized I pulled the dizzy based on putting it into the Explorer motor, not mine. I'm 99% sure the gear is wrong. I pulled it from a 5.0 1990 Lincoln Town car. The gear looks machined and I think that means its steel. I need a cast iron gear for my flat tappet camshaft.
Sooooooooo....................
After doing enough reading to develop a good case of automotive hypochondria, I don't know what to do. Do I replace the gear on 21 year old Lincoln dizzy? Buy new manufacture? or reman? dizzy from local Carquest? I guess if its "new" then everything is new, not "20 years old, but tested out ok". I'm not a fan of putting a bunch of time, money & effort into a part that is older than most the kids at Western State. I'm also not a fan of buying Chinese junk that isn't going to hold up.
Dan does your extra dizzy have the cast gear or steel gear? The cast gear dizzy would have come from a non-HO, non-rollered motor. Do you have an Explorer throttle cable? I think we had a conversation about that in Tin Cup.
Chad
Sat Oct 29, 2011 8:48 pm
I pulled the EFI stuff off the motor today. Everything went well. So easy working on an engine stand. Motor looked good, still coming to grasp with possibly selling it. Zilla's new tool got me wondering, so I borrowed a video scope from a mechanic & looked in the cylinders & there is still cross hatching visible.
I got the whole wire harness disconnected, only breaking one tab off one injector plug. Since the harness comes with the Mustang plugs, and these seem to be in ok shape, can I plan on taking these out of the loom & using them?
What vac lines will I be using? I run hydroboost, so don't need vac for brakes. PCV & pressure reg are the only thing I can think of. Cap the rest?
Is BCB's wire harnesses the exact same as RJMs? I want to make sure I get the plug in for the Baumanator & OBA. If it comes unloomed, it looks like you don't get that stuff. I'll sent an email to RJM asking about that.
Viper, I saw you recommended Fel Pro intake gaskets without the hole for the EGR gases, but can't find my link, can you give me those numbers again?
Are the Explorer valve cover gaskets reusable?
Is there a way to wire a regular dizzy for remote TFI, and use a remote TFI like the Lightning one? In the CB.com thread above, someone mentions that the dizzy for remote mount TFI was too big & didn't fit, I don't want to risk that. I think I can seal up the bottom of the regular dizzy, but I don't like the look of the exposed wires on the TFI module after it is remote mounted, in the rangerstation.com thread. I want the best of both worlds, but I'm not smart enough to figure it out.
Chad
Sun Oct 30, 2011 6:20 pm
The HO motors used low tension oil rings so cylinder wear doesn't seem to be much of a problem with them.
Did you compare all the connectors to the pics at RJM? Which are different?
PCV and fuel reg need vac. That should be it unless you want to use some smog equipment. It's nice to have one port available for troubleshooting though.
Felpro 1250S3 is the gaskets you want. Don't get 1250.
One of those links above shows the standard TFI distributor converted to remote. Just need 3 wires and terminals and move the TFI plug to the remote location.
Sun Oct 30, 2011 7:16 pm
Thanks, I haven't compared plugs yet. I'll post up what I've got.
I was just rereading "Tito"s Explorer swap thread over on CB.com, lots of good info, now that I've had a more close look at what I've got.
http://classicbroncos.com/forums/showth ... ost1074810
Can anyone recommend heater hoses to use with the Explorer heater tubes? And another way of remounting the ECT than drilling & taping like Tito?
I wanted to use the factory remote TFI because I don't like the look of the open connectors on the remote mounted TFI in the thread. Its not the end of the world, I just like the factory sealed connectors.
Chad
Sun Oct 30, 2011 7:33 pm
Here is what I've got:
Injectors: old style
IAB: new style
ECT: new style
ACT: I have one of each. I got the Explorer ACT (new) & air inlet tube, also got the ACT (old) from a Taurus SHO w/the MAF- weird, the SHO ACT is in the air filter box, before the MAF.
MAF- 89-95 style
The TPS is not shown in his products list here is a pic:
Chad
Sun Oct 30, 2011 8:34 pm
Mon Oct 31, 2011 12:27 pm
If you end up with 2 sets, I know someone who will need one.
Chad
Mon Oct 31, 2011 12:31 pm
Rox where did you find them for $37.00, Summit Racing is $45.00.
Well I was going to try to see if a dizzy for a remote TFI would fit, but I've done all the searching I can, on Rockauto & Napa and cannot find one with a cast iron gear. So I'm going to use the standard dizzy and remote mount the TFI.
I have 3 options for new dizzys. I can get a rebuilt one from Carquest for 65.00 + 40.00 core. I can get the new one from Rockauto for $75 + no core, so I'd still have the steel gear dizzy. Carquest is looking into other options. I'm leaning towards the new one, both are Cardone brand. Napa lists their rebuilt dizzy for $91.00 + 44.00 core. I don't get good deals there, so is there any reason to spend more for a Napa (unknown brand, but very close to the Cardone part number).
Chad
Mon Oct 31, 2011 6:41 pm
Viper did the Autozone heater hoses work out? I was thinking about cutting & flaring my Explorer heater lines, they are pointing up. Is the small bypass line important to keep coolant circulating or can I loose it? I don't see one on your Mustang set up pics, but I maybe missing something.
Dan, Rox how did you route your heater hoses, or plan to? Looks like maybe a big loop of heater hose may work, but I've got a lot going on, with a set of T's that feed an aux heater, and my OBA filters are there too.
Chad
Mon Oct 31, 2011 6:48 pm
Mon Oct 31, 2011 6:55 pm
Mon Oct 31, 2011 6:57 pm
Autozone M4336. I don't have an Autozone here so I may have to do some mail order or something. Those hoses fit his set up with Mustang heater lines, they end straight. He's got pics here:
http://classicbroncos.com/forums/showth ... se&page=10
post #138
There is a good pic of the Explorer hoses here:
http://classicbroncos.com/forums/showth ... light=hose
post #3
Mon Oct 31, 2011 7:06 pm
Actually it looks like they may still fit. I'm going to check at Carquest tomorrow and see if they can crossref the Autozone #, if not could you pick up 2 extras & I'll pick them up with all my other stuff.
Mon Oct 31, 2011 7:10 pm
Love the internet
PN# D87681
BUICK SKYHAWK (1982 - 1986)
CADILLAC CIMARRON 1982
CADILLAC DEVILLE (1985 - 1987)
CADILLAC FLEETWOOD (1985 - 1987)
CHEVROLET CAVALIER (1982 - 1986)
FORD RANGER XL 2009
FORD RANGER XLT 2009
JEEP CHEROKEE 1987
JEEP CHEROKEE CHIEF 1987
Mon Oct 31, 2011 7:15 pm
Mon Oct 31, 2011 8:39 pm
Spent the last couple hours on a wild goose chase. I don't think there are any "new" dizzys out there.
Chad
Mon Oct 31, 2011 8:58 pm
Mon Oct 31, 2011 9:10 pm
Wow, was looking for Cardone & others, I'm double checking the pn, needs a cast gear. Thanks
Mon Oct 31, 2011 10:11 pm
Both of these look right according to the description & application guide. Is there a difference between the one for the automatic and the manual. The one listed for the manual has a bluish looking gear. I can't cross ref the numbers anywhere. I assume the "Interchange Part Number" is some secret junk yard cross ref.
I think I'll pull the trigger on one of these tomorrow. If someone can help id, or tell me the difference I'd appreciate it:
http://www.ebay.com/itm/NEW-OEM-DISTRIB ... _500wt_716
Here are some that are for roller cams, go get them boys, leave the cast gears for me:
EDIT: Couldn't wait bought one for the manual, really I don't think there is a difference & all trucks came w/non roller cams till the mid 90's I'm pretty sure.
Thanks a ton Rox, that is one awesome price on a hard to find part. I couldn't be happier putting a NEW Motorcraft dizzy in. I owe you one! Now I can justify buying a new Motorcraft TFI & have my junk yard M/C TFI for a back up part! thumbs up
Chad
Mon Oct 31, 2011 11:02 pm
Somehow, I always manage to screw these things up.
Will someone have a look and tell me what you think. The dizzy listed as a "manual" truck model has a much thicker shaft between the dizzy & the gear. The one for the auto (the one Rox posted) has the same shaft as the Lincoln one I have.
Chad
Mon Oct 31, 2011 11:59 pm
One thing you can do is just get the new dizzy you want and press on the cast gear you need. I had to do that when I converted my 460 to a roller cam. The steel gear for me was 90$ and I chipped the first one. Suck'd so bad to see $90 just sit there broken. It's not too hard to do with basic tools you should have.
Tue Nov 01, 2011 6:09 am
If I knew the dizzy for the remote TFI fit, I would have bought it, and swapped to a cast gear.
Hopefully I chose right. I think I'm fine. Last night, I THOUGHT the dizzy had a different shaft than the one I need, but I had looked at too many pics of dizzys in one night & it was up past my bed time. loco
I ran out to the garage & looked at the one I had, and it actually looks just like the one I bought (the one for a "manual"). I think the differences are minor/cosmetic/different revisions. If I get a steel gear, I'll buy a new cast gear & swap them.
I'll probably quickly test fit it into my Explorer motor & maybe even my motor, so I can return it, if it is wrong, but I don't think it is.
Chad
Tue Nov 01, 2011 7:33 am
Ford used 2 different size shafts. I don't know why. Could be related to oil pump driveshaft size difference between 302 and 351w.
Tue Nov 01, 2011 10:09 am
That is a great chart to see. Blue = cast iron = awesome!
What concerned me was the diameter of the shaft above the gear. I wish I could claim I saw the .064" difference in gear diameter in the pics. But now that I know what to look for, I'm sure I'll spot a 0.467" gear shaft from a mile away. LOL.
Thanks a bunch for the help. Its real nice to have people who have actually done this stuff & give advice. I certainly don't know anyone in Gunnison that has done this, let alone anyone who would put up with my incessant questions & comments.
I'm becoming FMCEFIOCD. I have started looking up stuff that doesn't have anything to do with my build, just cause I want to know. My head has been spinning for the last few days, I find my mind wandering from tasks at hand to thoughts of remote mount TFI dizzys with cast iron gears, and the vehicles they may have come from........ When I drive around I see crappy old Mercury Cougars w/ V8 emblems and hit the brakes, I can't pass an Explorer or Mountaineer without looking at the fender for the V8 badge. I have an ever evolving list of "needs" running around in my head, and on 2 or 3 different pieces of paper, in my house & shop. Thanks again, I need the support of people who have been there, the first step is admitting I have a problem, I know.
Chad
Tue Nov 01, 2011 12:31 pm
I was browsing the other items available from the guy selling the dizzys.
I think I know the answer, but anyways, how difficult would it be to adjust an OEM Speed Density engine/ecu harness to fit a Mass air. Also the harness uses a remote tfi type dizzy & wiring. Probably have all the wrong sensor & injector plugs. Is it worth saving $400 over RJM?
http://www.ebay.com/itm/NEW-OEM-ENGINE- ... _500wt_716
Chad
Tue Nov 01, 2011 8:35 pm
That is a bad idea, there is a big difference in how the injectors & tfi are wired, far beyond my ability. Not going to try to reinvent the wheel.
Oh well.
Chad
Tue Nov 01, 2011 9:40 pm
So I finally clicked the right link & found the list of connectors that come in the kit. Pretty much what I figured. I only need to swap 3 connectors to make the harness fit, no big deal. If I stumble on the older parts I'll use them, but otherwise I'm not going to worry about it.
Since I didn't get a throttle cable at the yard I need a cable. Any thoughts. I need to study the BCB cable kit & see if it can be built. I was reading on the throttle problems with Explorer EFI and think I'm going to try this:
http://classicbroncos.com/forums/showpo ... tcount=116
I don't have a Mustang throttle body so I have to rig something else up. I even found one crazy set up using 1/2 a pulley. Still haven't figured that one out from the pics, should have taken a close look at Chinamen's.
And, I've got a cool surprise coming. It maybe a little while, but a friend is making me something cool. It will defiantly get posted when it arrives.
Chad
Wed Nov 02, 2011 6:07 pm
Don't knock the half pulley. It works great. I've done that to a completely stock explorer TB using the entire pulley too.
Wed Nov 02, 2011 6:23 pm
Ha, just kidding, I'm sure its slick. I just can't figure out whats going on from the pics I saw at CB.com.
Thanks Dan. I'm thinking of using the BC kit. Good to know it only takes a little work with the pedal to get it right. I've got a torch, no problem.
Chad
Wed Nov 02, 2011 6:26 pm
Vipers pulley system looks slick. I want to see it in action someday. I just extended the arm on my TB and it works fine too. I also have the pivot on my pedal adjusted. Mine was like a light switch, either all off or all on, which is the opposite you want while wheeling. Now I can feather the throttle.
Wed Nov 02, 2011 9:26 pm
32,969,176 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
