Register •
FAQ
• Login
It is currently Sun Sep 29, 2024 5:20 am
Hub Heat- Calipers not fully releasing
Re: Hub Heat- Calipers not fully releasing
Glad you got it sorted!
Sun Mar 18, 2012 9:03 pm |
nice dude! glad you got it sorted and you didn't have to replace any of the big stuff.
Sun Mar 18, 2012 9:12 pm |
Hey Shawn, do those levis make your butt look fat?
Sun Mar 18, 2012 9:39 pm |
I can't imagine the hose was the culprit either.
A pinched steel line I could see that but not a rubber hose.
Mon Mar 19, 2012 7:57 am |
Gregg
It wasn't a night / day change. It was just a good improvement. The center hose was starting to deteriorate on the outside and it was the only hose (other than steel) not replaced during the disc conversion. I don't know of any other test other than replacing MC / or calipers. My understanding about the H block is it doesn't change pressure but directs the fluid.
And Viper- No, my butt makes the Levi's look PHAT.
Mon Mar 19, 2012 8:24 am |
My assumption when I read this was that the hose was deteriorating inside and that some little piece of crud was hanging up when the fluid reversed direction. Greg, you're right about the H block. It isn't a proportioning valve.
Mon Mar 19, 2012 12:26 pm |
