It is currently Fri Oct 04, 2024 11:26 am
Disc Brake Conversion Advice needed
Re: Disc Brake Conversion Advice needed
Nice! I'm sure you are going to like the results. Makes a huge difference.
Fri Oct 31, 2014 7:37 pm |
If your old ones are the stock ford hubs I'm looking to buy a set.
Fri Oct 31, 2014 8:58 pm |
phyler
Justin, I'm coming from drums so I have all of that. If you need anything from that setup let me know. I have the spare hub from disc setup but the bolt holes for the wheel studs are a bit wallowed out. If you can use it, it's yours. I think you have my number.
Fri Oct 31, 2014 9:06 pm |
I think he meant the locking hubs.
How were your drums?
Fri Oct 31, 2014 9:45 pm |
phyler
Ah, I had a set of warn on there before and one is in pieces.
Drums are in good shape. One spindle /backing plate is bad as the threads on the spindle are wrecked.
Fri Oct 31, 2014 9:47 pm |
phyler
Latest in the saga, I can't get the fronts to bleed correctly. Backs go quickly. The fronts just keep pushing air. I've used a small bottle and almost two large bottles of fluid. I can't imagine there is that much air in the system. Ugh.
Sat Nov 08, 2014 10:24 pm |
Moab Mike
Did you bench bleed the master cylinder? If yes then you have a leak in a fitting somewhere that is allowing air to get in. Check the tightness of all the fittings.
Sun Nov 09, 2014 9:13 am |
phyler
I'm using the stock master. I realized I didn't check for the residual valve. I'm going to do that today. Then I'll re-bleed the entire system starting with the master. Just want this done before the cold hits tomorrow.
Sun Nov 09, 2014 9:19 am |
phyler
Verified there is no residual valve. Can someone either confirm my setup or tell me that I'm an idiot and have the calipers on the wrong side? Here is a pic of the passenger side. I thought the bleeder valve should be higher than where the hose connects but maybe I'm off on that thought.
Mon Nov 10, 2014 8:10 am |
They look upside down. The hose & bleeder should be on top.
Mon Nov 10, 2014 8:15 am |
phyler
Thanks! I was thinking I managed to mess that up even though I was trying to be careful.
Mon Nov 10, 2014 8:43 am |
x2, your calipers are upside down. Ask me how I know....
Mon Nov 10, 2014 9:15 am |
