rooster wrote:That's great guys, as I already have a 3/4 " metal bit and access to a press
How is everyone going about trac bars? I wanna make sure I cure all bump steering in this process.
Iwas tossing around the idea of possibly pushing the front axle forward an inch or so as the the BNG arms have some adjustment , but wouldn't this cause the trac bar bushings to bind ? Anyone ever make their own with hiem joints on either end to avoid that? Or am I just over thinking and complica6 things to much?
Thanks guys
I left mine in the stock position. Justin could speak more about what it takes to push the axle forward. Usually springs, shocks, steer box all need to move with the axle.
Switching the tie rods to the top of the knuckles may result in clearance issues. I had to relocate the frame-side trac-bar mount rearward 2 inches. I also built a trac-bar riser on the axle side to improve the suspension geometry. This however required a custom trac-bar with a slight hook in the end to clear the frame and spring buckets at full jounce.
Tie rod interference and moving the frame bracket
Trac-bar riser
Watch your axle clearances to the frame and oil pan too!
FWIW I avoid rod ends for a street driven vehicle. There are better options these days that will perform better and last longer. I used a JK tracbar bushing and an aftermarket cross-axis ball joint on my rear track bar. I will likely do the same on the front. You will appreciate have some isolation in the system and a cross axis joint can handle mis-alignment.
