www.ColoradoClassicBroncos.com - View topic - EFI conversion questions - lots of random ones
It is currently Sat Nov 23, 2024 7:19 am
Reply to topic  [ 222 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Post Re: EFI conversion questions - lots of random ones
So everything is moving a long well, but I've misplaced the damn ECT sensor. I'm hope I'll run across it tomorrow, or hopefully Carquest or Napa will be open & I can get one. Tomorrow I need to get the throttle cable installed to the gas pedal, install the upper intake, t/b, mas, & air filter, wire it, and reinstall the HP pump & accumulator, radiator & new clutch fan. It will be a long day.
Chad
Sun Dec 25, 2011 10:40 pm
Looks good chad. It will be nice to have EFI.
Mon Dec 26, 2011 8:54 am
Trouble reared it's ugly head in the form of hydrobooster/intake manifold interference. Also the intake is riding on the hood, but an air saw will fix that.
Gonna take my old angled power brake booster back this afternoon and see how I can move my booster. Not going to run today.
Mon Dec 26, 2011 1:39 pm
keep at it brother
curious that your having fit problem
the angled bracket will fix it
Mon Dec 26, 2011 4:10 pm
Mon Dec 26, 2011 8:28 pm
Track down Vintage Iron Fabworks on CB.com. They make a simple bracket for $10 that allows you to rotate the HB unit 90 degrees. May solve your problem.
Mon Dec 26, 2011 8:39 pm
Thanks
Is this what you are talking about:
http://classicbroncos.com/forums/showth ... p?t=193028
I saw those a while ago, but forgot about them. I wonder if I could just flip the h-booster over 180, so the accumulator was at 5 o'clock. I'll do some staring tomorrow.
Chad
Mon Dec 26, 2011 8:56 pm
Justin, thanks for making me think about rotating the h-boost.
I can't use the product you suggested, rotating the h-booster 90, 180, or 270 will all interfere with either the valve cover, intake, or steering shaft. But as a quick fix to get the truck running, I can rotate it about 20 degrees clockwise & still maintain clearance. Unfortunately, it doesn't' give me a way to mount the master cylinder, even with a custom cut adapter plate. The m/c will be slightly off level, but I don't think it will matter. Before I do much driving, I'll have to rebuild my angle bracket & fab up a new system. I was hoping to do it without opening the brake lines, but that isn't going to happen.
I swapped the ECT, IAB, and TPS sensors from my 351, to match the RJM harness.
Is it a problem that I drove my truck for a couple weeks with O2 sensors installed without being hooked up? Can/should I clean them? I hope I didn't ruin them.
I'm going to start wiring it and then hook up the fuel pumps, should be ready to fire up then. Assuming my h-boost is easy to fix. I bought the unloomed RJM harness, and now I'm glad I did, I think I'm going to have to move a few sensors.
Thu Dec 29, 2011 9:16 pm
A little angle won't hurt the master cylinder. I was thinking of clocking mine the same.
I don't think you would have damaged the O2 sensors. Definitely try them out before anything else.
Thu Dec 29, 2011 9:26 pm
Everything I have read about o2 sensors say that will ruin them. But try it and see.
Fri Dec 30, 2011 7:11 am
Thanks guys, I guess there is only one way to find out, that is to fire it up. I'll do my best to make that happen by the end of the weekend. I'll keep you updated, and try to take some more pics.
Chad
Fri Dec 30, 2011 8:27 am
Fri Dec 30, 2011 8:29 am
They heat up when the system is on, and it keeps them clean. If mine have gummed up, they may not clean up and read correct. I think.
Fri Dec 30, 2011 8:33 am
Fri Dec 30, 2011 11:15 am
Home for lunch more photos.
Got the h-boost rotated & mounted yesterday, and the gas pedal bolted in.
Today I've finished cutting open the wiring harness & temping it in. I cut the hole to route the harness & pulled it through.
Now I've pretty much reassembled everything & run the wires to most the locations, I need to lengthen the ECT & IAB wires.
The list & pile of parts is getting smaller.
Sat Dec 31, 2011 2:49 pm
Sat Dec 31, 2011 5:26 pm
Sat Dec 31, 2011 6:06 pm
Kept plugging away at the swap this afternoon/evening. Only took one pic, just before the upper intake went on:
Got lots of wire loomed, and further organized. Added a little dielectric grease to all the connections as I've gone. Throttle body is installed & throttle cable "adjusted". I had to make some small changes after I realized the throttle body wasn't closing completely.
Still need to drop the dizzy back in, finish wiring & plumbing under the truck, and make the final electric connections to the RJM harness. I also need to make a bracket to mount the MAF & airfilter, and mount the coil & BP sensor, plus keep looming wire. I'll clean up the O2 sensors with some scotchbrite & keep my fingers crossed. My only fear is that the truck ran most mornings with the carb choked, but I also made some longer trips that got things heated up.
Sat Dec 31, 2011 9:22 pm
Two more full days working, less a few hours to paint a Scout door, and its still not done. I did do a little backtracking, my airfilter/maf plumbing didn't work, the air filter was in the top of the battery.
Lots of tedious progress today, but no pics. I checked out an O2 sensor, and there was a little carbon, but not much else, so I cleaned it w/some scotchbrite. The right sensor is a PITA to get out, so I left it in, considering how the other one looked. Modded/painted & mounted the coil & bracket from the 351 motor. Stabbed the dizzy roughly enough to start & get a timing light on. More wiring routed & tied down, mounted BP sensor, installed spark plug wires, & battery. Started working on installing the HP pump & accumulator, it should go quickly, the mounts are done.
All the hardware & auto stores were closed yesterday & today, so tomorrow I've got some stuff to buy to get things finished. I'm going to change my battery & alt grounds, hopefully to fix my charging problems.
I'm down to finishing the accumulator/hp pump plumbing & pump wiring, and the powered connections to the harness, then I think its ready to go. There will still be some things to clean up, but I think I see the light at the end of the tunnel.
Thanks for all the help.
Chad
Sun Jan 01, 2012 8:52 pm
Great work Chad, it looks like your coming along nicely. It should be purring like a Lion in a matter of days. {:-)
Sun Jan 01, 2012 9:01 pm
Looking good Chad.
Sun Jan 01, 2012 9:22 pm
Thanks guys, it'll be up & running soon.
Sun Jan 01, 2012 9:41 pm
Chad, in the last pic... it looks like you were able to keep the temp sensor in the stock location?? I didn;t think it would with the dizzy installed. If so, ow much room do you have to adjust timing?
Sun Jan 01, 2012 10:26 pm
You are right, I kept it in the manifold, because I didn't build a bypass in the heater hose, and thought it would be more accurate. I have lots of room to rotate the dizzy, probably 30d. I think the Explorer front accessories limits the rotation, but mine seems to have plenty of room. I'll take a better pic tomorrow.
Sun Jan 01, 2012 10:33 pm
Pretty much took last night off, but got back at it today & made some good progress.
Here are a couple pics of the dizzy clearance I have:
When the dizzy is turned all the way counter clockwise, the cap adapter hits the fuel rail, not the sensor.
Here are a couple pics of air inlet V2.0. I pulled the ACT apart, separated the twist lock part (it used to fit in the airbox of a Taurus SHO) and glued it into a new elbow. A 3" ABS 90d sewage elbow fit perfect between my air filter, yeah kinda ghetto, & the MAF fittings (the MAF & rubber reducer between the MAF & elbow is also from the SHO). I actually like this better, than V1.0, using the Explorer plumbing. This way the ACT threads into the elbow, not twist locks.
Also got a little more done with my fuel pumps & accumulator. I put my old belts back on and decided to return the new ones. I'm going to install a double v-belt pulley on my alt, now the new 69 GTO coolant hose makes room for a second belt. I've had the pulley for a while, but no easy way to install it. I wonder if the belt was slipping, causing no charge, but I never heard it squeel. I'll get back at it tomorrow after work.
Here is the finished Scout door that has prevented me from getting my Bronco done. But now its done, so no more getting sidetracked. The color match looks better outside, but we had no codes to work from & even our computer match sucked.
Tue Jan 03, 2012 9:15 pm
Keep up the great work Chad..............yesterday's snow bashing trip was motivational but I still took a break tonight.............I can only keep pace for so long.
Do you know McGyver ?
icon biggin
Tue Jan 03, 2012 9:29 pm
I've been called McGyver a few times in my life. Once earlier today, while putting a Thule rack on a friend's 4Runner. The first time was at a party in Crested Butte, someone had an English keg with an American tap. That equals no beer. I saw a pile of discarded ski poles & asked for a hack saw & cut a small section of ski pole to act as an adapter to fit the tap to the keg. I was a HERO!
Living in Gunnison makes you pretty crafty. You should see how some of the houses were built around here. Necessity is the mother of invention.
Tue Jan 03, 2012 9:33 pm
Good progress. Almost ready to fire.
Wed Jan 04, 2012 12:06 am
Chad do you have a screen in front of the MAF? if not with it right before your bend you will not get accurite readings. I dont want to see you fry that motor cause your maf is in the wrong spot. You need a a straight section ~5-6" before the maf to let the air "straighten out". If you put a screen in front of it it will straighten the air and you wont need the straight piece in front.
Wed Jan 04, 2012 7:16 am
Thanks I did not know about the screen/straight section. The MAF has a factory screen on the inlet side of the sensor, is that enough?
Wed Jan 04, 2012 8:29 am
32,969,014 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
