Why is the firing tip/igniter on the Champion so much smaller? Is that ok? I’m running a ‘93 5.0 w/Mustang EFI if it matters.
mickphatmac wrote:What Rob said
horseplay wrote:Hey Scott so 1993 5.0 should use a Motor craft ASF4CA plug. stay away from champion plugs for your application they don't work well. Also platinum and Iiridium plugs don't perform well with older ignition systems. Both the champion and NGK plug look to have to long of a reach.
horseplay wrote:Looks like you got the right plug. I'm assuming the reach on the plug is the shorter version.
