A client brought us a 66 Bronco w/ a 289 HP/HO engine, after installing a Holly sniper EFI system w/ the hyper spark management system. Client stated "could not get the engine running". He stated he could get it running & idling, but experienced backfires when trying to get the vehicle in gear. Backfiring was not explained in detail. After getting the truck into a bay & starting it, I had noted the engine was extremely hard to start. had to hold throttle to floor to achieve a turn over (doesn't pop off). after a few minutes of running, engine would backfire out of the intake and stall. Talked w/ holly about this system (plug and play.... right.). they had informed me about a sporadic spark issue they've been having w/ there ignition boxes. I mapped ignition timing & saw timing jump to approx 40 degrees btdc every time I got a pop out the intake system. I'm pretty sure that's an issue... but what i'm wondering. While i had the engine running, i saw excessive amounts of fuel vapors coming from the crankcase. billowing... i dropped the oil from the engine, it was extremely diluted and non viscuse. replaced the oil w/ little to no positive gain. ran a compression test and got pretty even numbers. highest 90 psi, lowest 75 psi (dry & cold) i know it has to be warm for an accurate reading. wet i got a positive increase of 10 psi across the board. My question is, does anyone know, or can anyone tell me w/ consistency what a high output 289 ci is supposed to produce during a compression test??
Any info? preferably factory info, not your guess or seat of the pants ideas.. pretty please.
