Rate my rust
Rate my rust
Postby laffycaffi » Wed May 08, 2019 5:06 pm
I admit I'm a novice at understanding the impact of rust in early broncos and this video has me nervous. https://youtu.be/5YhlQ9_sGlc
Attaching some photos of my rear quarters and some other areas. How bad of shape am I in?
When the guy in that video says the rust is causing problems, what kind of problems is he talking about?ImageImageImageImageImageImageImageImageImage
Sent from my SM-N950U using Tapatalk
laffycaffi
Re: Rate my rust
Postby phyler » Wed May 08, 2019 5:22 pm
Rust never stops. Bottom line, if you have it, it will continue to spread. Those seams look like they have a good amount. If you look at my build thread (Project Downward Spiral), you can see what I found when I removed my lower quarters and I had less bubbling than what I see in yours.
That said, if you aren't in a place to tackle it, don't start. Drive it until your ready. It will be more work than you plan.
phyler
CCB Admin
Re: Rate my rust
Postby laffycaffi » Thu May 09, 2019 4:50 am
Wow, that was quite a project! How long total was your rig out of commission for the body work that you did? Looks like you did an amazing job.
Your comments about "Well we didn't go skiing so I figured I'd work on the Bronco" and "Since the Broncos are playing, I feel it would be a good time for an update" had me laughing because that's my life exactly. Everything revolves around skiing and Broncos games. And work.
phyler wrote:Rust never stops. Bottom line, if you have it, it will continue to spread. Those seams look like they have a good amount. If you look at my build thread (Project Downward Spiral), you can see what I found when I removed my lower quarters and I had less bubbling than what I see in yours.
laffycaffi
Re: Rate my rust
Postby phyler » Thu May 09, 2019 7:19 am
Well, life got in the way, a lot. I travel for work, plus kids (I coach youth soccer too). Technically, 90% of that was done in 2 years but that was me going very slow cause I had/have zero clue at what I'm doing.
Then, I got to the point where I needed to spray epoxy primer and winter came so the project sat (epoxy needs metal temps of 65 degrees or warmer). Then last summer, work had me on the road 10 weeks straight so I got epoxy layed down but then winter came back before I could prime/paint. So, here I am at 4.5 years. I really just need to rebuild the power steering box and I could drive it. It is epoxied and my goal is to primer it and paint it in June this year. We'll see if it all works out.
If you have time, this can be done much faster. Look at Strike2, he did 1000% more in 25% of the time of my project. Also, if you aren't trying to paint it (i.e. you'll farm that out), you can get that done during the winter from a shop. I'm doing it all in my garage.
phyler
CCB Admin
Re: Rate my rust
Postby Stubborn3 » Fri Jun 14, 2019 4:02 pm
Haha... your rust is amateurish at best !
Stubborn3
Re: Rate my rust
Postby BOBS 2 68S » Sat Jun 15, 2019 5:59 am
And steer clear of hail storms. My pictures on "What sux thread"
BOBS 2 68S
