Per my other post about pulling my transmission (to change out my clutch)...
I dropped off my flywheel and got a call back, the guy at Napa is perplexed. Here's what he told me:
1. Flywheel is not serviceable. The starter is hitting it too deep. It's hitting the flywheel itself and not just the teeth.
2. His catalog shows that the small block calls for an 11" clutch, but the wear patters seems like I have a 10" clutch installed. That said, the flywheel that I dropped off is a 164 tooth flywheel.
3. Given the damage that the starter is putting on the flywheel makes him suspect it really needs a 157 tooth / 10 inch clutch, but that goes against what the catalog suggests.
So he's confused and I personally have no idea. I did notice that my new clutch which I ordered from them looks larger, but I haven't had a chance to measure it yet. Maybe I had a 10" clutch on a 164 tooth flywheel? Is this possible? And does that even relate to the damage that the starter has put on the flywheel?
Not sure what I need to do. Insights appreciated.
