[phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4794: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4796: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4797: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4798: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) www.ColoradoClassicBroncos.com - View topic - Greasy hands and clutch plate.
Now that I've got the new clutch installed and bellhousring secured, I'm watching more videos on YouTube and two came up stressing the importance of handing them with clean gloves.
I guarantee that I handled them with pretty dirty gloves. I'm sure there are grease smudges on the plate.
I got grease on the flywheel and pressure plate, but cleaned those off with brake cleaner.
Should I remove everything and start over and buy a new plate?
That would suck. But I'll do it.
Sent from my SM-N950U using Tapatalk
Sun May 19, 2019 9:13 pm
BOBS 2 68S
Re: Greasy hands and clutch plate.
Take it apart and clean it with brake cleaner. If in doubt replace the plate
