Where is the best place to “wire” my fuel pump?
I will be mounting it on the frame rail very close to my rear main tank and grounding it there as well.
Where is the best and EASIEST place to run the hot wire?
ZOSO wrote:You may want to measure voltage off that post. For some reason I believe it only provides about 9volts as it's running.
horseplay wrote:That is correct you don't want to use that I terminal. come from ignition hot to a relay to carry the load of the fuel pump.
Gunnibronco wrote:horseplay wrote:That is correct you don't want to use that I terminal. come from ignition hot to a relay to carry the load of the fuel pump.
Sorry for the bad advice. I guess I haven't even worked on or driven a Bronco in so long I can't remember how things work. I don't remember what is hooked up to the starter solenoid anymore.
