When I was switching gears and went into higher RPM range it made a noise like there was break dust but it couldnt have been the breaks, and almost simultaneously the headlights went out. but the break lights, and all the other electronic systems are fine.
I put a headlight relay switch on so that theyd not over heat due to the higher intensity on modern day head lamps, and I am wondering if that could have failed? in addition to that, i cross wired my battery when i was jumping my car and i was lucky the alternator didnt blow out but now im wondering if it finally did give out, or possibly the voltage regulator?
also its a 69, i dont know the history of the vehicle but is it possible that it could be time for a new clutch? and maybe the serpentine belt is loose and that is what happened and thatd explain the intense squealing at higher rpms and why the head lights were being weird.
anyhow, its about 11 o clock and im going to take a look at it tmrw, suggestions? thx!
