12v fuel pump electrical hook up question
Postby mickphatmac » Sat Sep 14, 2019 10:49 pm
I think I kind of asked this question before but now I’m actually in the middle of it and I want to know if I can run my hot positive wire from my fuel pump into the engine bay to the wire that goes to the positive side of my coil ?
Is that the same wire that comes off of the “RUN” Side of the ignition?
ThankYou
Images: 14
Re: 12v fuel pump electrical hook up question
Postby Viperwolf1 » Sat Sep 14, 2019 11:16 pm
It is the same wire but it's probably not a good idea. You really don't want to rob current from the coil and it's going to be at reduced voltage anyway because of the resistance wire. You can use it to trigger a relay though.
Postby mickphatmac » Sun Sep 15, 2019 5:16 pm
Ok perfect! Thanks again!
Images: 14
Postby mickphatmac » Tue Sep 17, 2019 7:00 pm
This is what I ended up getting...
Images: 14
Postby mickphatmac » Sun Sep 29, 2019 7:08 pm
I had the pump working and drove it for the first time today and the engine actually ran for about 25 minutes or so while we dialed everything in and checked for leaks and fixed leaks and little problems before we drove it and the fuel pump died, will hook the fuel pump up to 12V and see if we can trace the problem I guess
Images: 14
