Limited Slip Dana 44?
Postby Moab Mike » Wed Feb 23, 2011 4:39 pm
OK, so I have been trying to figure out if the front axle in my 76' is limited slip or not. I know the rear axle is. Here is what I have so far......
The shop manual I have says the front axle is a J or J8 code depending on how you read it.
The ID tag on the glove box gives the axle codes as "B8J" or B8 for rear "locking" and J for power steering.
I have deciphered most of the tag on the axle as;
3.54 Gear Ratio
D6TA AJC as D = 70's, 6 = 76', T = Truck, A = Unknown AJC = Unknown
BOM 603421 3
Any thoughts?
Moab Mike
Re: Limited Slip Dana 44?
Postby Viperwolf1 » Wed Feb 23, 2011 5:56 pm
B8J-B8 is 3300 lb rear axle with 3.50 gears and limited slip. J is power steering.
B8Q would be that same rear axle plus power steering and front limited slip.
Postby Moab Mike » Wed Feb 23, 2011 5:58 pm
zillacon wrote:What does the tag on the axle say if its still there?
Here is the only tag on it.
Moab Mike
Postby Moab Mike » Wed Feb 23, 2011 6:02 pm
Viperwolf1 wrote:B8J-B8 is 3300 lb rear axle with 3.50 gears and limited slip. J is power steering.
Thanks Viper, sounds as if I'm only limited slip in the back.
Moab Mike
Postby akaFrankCastle » Wed Feb 23, 2011 10:46 pm
603421-3 shows as a standard 3.54 Dana 44 according to the Spicer parts catalog. Sorry bro.
Postby Brianut » Thu Feb 24, 2011 7:02 am
you could always jack the front, lock the hubs and give one wheel a spin.
if they turn the same you have some traction device.
not sure if I would trust the tags as who knows what happened in the last 35+ years.
that is how I found mine was lim slip
Brianut
Postby Brianut » Thu Feb 24, 2011 11:17 am
yes i left that out. i layed under it and jabbed my foot againt the opposing wheel, things you gotta do when working alone.
Brianut
Postby Moab Mike » Thu Feb 24, 2011 2:07 pm
Thanks for the input everyone!
Moab Mike
Postby Jesus_man » Mon Feb 28, 2011 7:48 am
Brianut wrote:you could always jack the front, lock the hubs and give one wheel a spin.
I have always wondered if that works with Limited slip. Good to know it does.
If it's an open diff, the tires will spin in opposite directions.
